RG-ES126FGS-P - 1
RG-ES126FGS-P - 2
RG-ES126FGS-P - 3
RG-ES126FGS-P - 4
RG-ES126FGS-P - 5
RG-ES126FGS-P - 6
RG-ES126FGS-P - 7
RG-ES126FGS-P - 8
RG-ES126FGS-P - 9
RG-ES126FGS-P - 1
RG-ES126FGS-P - 2
RG-ES126FGS-P - 3
RG-ES126FGS-P - 4
RG-ES126FGS-P - 5
RG-ES126FGS-P - 6
RG-ES126FGS-P - 7
RG-ES126FGS-P - 8
RG-ES126FGS-P - 9
Compare
RG-ES126FGS-P
24-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 24 PoE+ Ports
RG-ES126FGS-P, 24-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 24 PoE+ Ports
Plug and Play
PoE 370 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 26
Number of 1GE combo ports
Number of 10/100BASE-T ports
  • 24
  • 24
  • 24
  • 370 W
  • 6.5 Mpps
  • 8.8 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
