RG-ES05
Fine Craftsmanship Exquisite and Powerful Design
Real 8-Pin Enterprise-grade Quality
Stringent Testing Worry-free
Plug and Play Energy Saving
Strong Adaptability Applicable for Various Scenarios
Matte-finish Diamond Pattern Design
Honeycomb Heat Dissipation Holes
Embedded Foot Pads
Hidden hanging Holes
Plug and Play & Energy Saving
Energy Saving
Auto Power Reduction
Fansless
Noiseless
- PoC Guide
- Reyee Switch PoC Guide V1.0-VN 2021-11-01
- Reyee Switch PoC Guide V1.0 2021-07-07
- Reyee Switch PoC Guide V1.0-TR 2021-11-04
- Installation Guide
- EU Declaration of Conformity
- RG-ES05_EU DOC 2023-04-27
