RG-ES106D-P V2 - 1
RG-ES106D-P V2 - 2
RG-ES106D-P V2 - 3
RG-ES106D-P V2 - 4
RG-ES106D-P V2 - 5
RG-ES106D-P V2 - 1
RG-ES106D-P V2 - 2
RG-ES106D-P V2 - 3
RG-ES106D-P V2 - 4
RG-ES106D-P V2 - 5
Compare
RG-ES106D-P V2
6-Port 10/100Mbps Unmanaged Switch with 4 PoE+ Ports
  • Plug & Play
  • PoE 54W
  • 3-Year Warranty
Unmanaged Switch, Which Is Visible on Ruijie Cloud App*
Large Buffer for Smooth Data Transmission
Hardware flow control, ensuring large buffer
Intelligent PoE Management
Application to various powered devices (PDs), single port with up to 30 W
High Network Reliability
Stability without frequent restart
  • Fanfree design
  • Green (802.3az)
  • Energy Saving
Adaptation to Various Scenarios
Key Specifications
  • 6
Number of 10/100BASE-T ports
  • 6
  • 54 W
  • 0.89 Mpps
  • 1.2 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
  • When port isolation is eN/Abled, ports 1-4 are isolated from each other, but can communicate with ports 5 and 6
