RG-ES116G-L - 1
RG-ES116G-L - 2
RG-ES116G-L - 3
RG-ES116G-L - 4
RG-ES116G-L - 5
RG-ES116G-L - 6
RG-ES116G-L - 7
RG-ES116G-L - 8
RG-ES116G-L - 9
RG-ES116G-L - 1
RG-ES116G-L - 2
RG-ES116G-L - 3
RG-ES116G-L - 4
RG-ES116G-L - 5
RG-ES116G-L - 6
RG-ES116G-L - 7
RG-ES116G-L - 8
RG-ES116G-L - 9
Compare
RG-ES116G-L
16-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
RG-ES116G-L, 16-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
Plug and Play
Gigabit Speed
3 Years Warranty
Energy Saving
Secure and Stable CCTV Network
Flow control and port isolation, ensuring reliablity and security
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 16
  • 16
  • 23.8 Mpps
  • 32 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
