RG-ES05G-L - 1
RG-ES05G-L - 2
RG-ES05G-L - 3
RG-ES05G-L - 4
RG-ES05G-L - 5
RG-ES05G-L - 6
RG-ES05G-L - 7
RG-ES05G-L - 8
RG-ES05G-L - 9
RG-ES05G-L - 10
RG-ES05G-L - 11
RG-ES05G-L - 12
RG-ES05G-L - 13
RG-ES05G-L - 14
RG-ES05G-L - 15
RG-ES05G-L - 16
RG-ES05G-L - 1
RG-ES05G-L - 2
RG-ES05G-L - 3
RG-ES05G-L - 4
RG-ES05G-L - 5
RG-ES05G-L - 6
RG-ES05G-L - 7
RG-ES05G-L - 8
RG-ES05G-L - 9
RG-ES05G-L - 10
RG-ES05G-L - 11
RG-ES05G-L - 12
RG-ES05G-L - 13
RG-ES05G-L - 14
RG-ES05G-L - 15
RG-ES05G-L - 16
Compare
RG-ES05G-L
5-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
RG-ES05G-L, 5-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
Plug and Play
Gigabit Speed
3 Years Warranty
Energy Saving
Visible on Ruijie Cloud*
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 5
  • 5
  • 7.44 Mpps
  • 10 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
