RG-ES110GS-P-L - 1
RG-ES110GS-P-L - 2
RG-ES110GS-P-L - 3
RG-ES110GS-P-L - 4
RG-ES110GS-P-L - 5
RG-ES110GS-P-L - 6
RG-ES110GS-P-L - 1
RG-ES110GS-P-L - 2
RG-ES110GS-P-L - 3
RG-ES110GS-P-L - 4
RG-ES110GS-P-L - 5
RG-ES110GS-P-L - 6
Compare
RG-ES110GS-P-L
10-Port 10/100/1000 Mbps Unmanaged Switch with 8 PoE+ Ports
RG-ES110GS-P-L, 10-Port 10/100/1000 Mbps Unmanaged Switch with 8 PoE+ Ports
Plug and Play
PoE 120 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 9
  • 9
  • 8
  • 8
  • 120 W
  • 14.8 Mpps
  • 20 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
