RG-ES08F - 1
RG-ES08F - 2
RG-ES08F - 3
RG-ES08F - 4
RG-ES08F - 5
RG-ES08F - 6
RG-ES08F - 7
RG-ES08F - 8
RG-ES08F - 9
RG-ES08F - 10
RG-ES08F - 11
RG-ES08F - 12
RG-ES08F - 13
RG-ES08F - 14
RG-ES08F - 1
RG-ES08F - 2
RG-ES08F - 3
RG-ES08F - 4
RG-ES08F - 5
RG-ES08F - 6
RG-ES08F - 7
RG-ES08F - 8
RG-ES08F - 9
RG-ES08F - 10
RG-ES08F - 11
RG-ES08F - 12
RG-ES08F - 13
RG-ES08F - 14
Compare
RG-ES08F
8-Port 10/100 Mbps Unmanaged Non-PoE Switch
RG-ES08F, 8-Port 10/100 Mbps Unmanaged Non-PoE Switch
Plug and Play
Fast Ethernet
3 Years Warranty
Energy Saving
Visible on Ruijie Cloud*
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 8
Number of 10/100BASE-T ports
  • 8
  • 1.19 Mpps
  • 1.6 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
