RG-ES110F-P - 1
RG-ES110F-P - 2
RG-ES110F-P - 3
RG-ES110F-P - 4
RG-ES110F-P - 5
RG-ES110F-P - 6
RG-ES110F-P - 1
RG-ES110F-P - 2
RG-ES110F-P - 3
RG-ES110F-P - 4
RG-ES110F-P - 5
RG-ES110F-P - 6
Compare
RG-ES110F-P
10-Port 10/100 Mbps Unmanaged Switch with 8 PoE+ Ports
RG-ES110F-P, 10-Port 10/100 Mbps Unmanaged Switch with 8 PoE+ Ports
Plug and Play
PoE 110 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 10
Number of 10/100BASE-T ports
  • 10
  • 8
  • 8
  • 110 W
  • 1.4 Mpps
  • 2 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
