RG-ES118FGS-LP - 1
RG-ES118FGS-LP - 2
RG-ES118FGS-LP - 3
RG-ES118FGS-LP - 4
RG-ES118FGS-LP - 5
RG-ES118FGS-LP - 6
RG-ES118FGS-LP - 7
RG-ES118FGS-LP - 8
RG-ES118FGS-LP - 1
RG-ES118FGS-LP - 2
RG-ES118FGS-LP - 3
RG-ES118FGS-LP - 4
RG-ES118FGS-LP - 5
RG-ES118FGS-LP - 6
RG-ES118FGS-LP - 7
RG-ES118FGS-LP - 8
Compare
RG-ES118FGS-LP
16-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 16 PoE+ Ports
RG-ES118FGS-LP, 16-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 16 PoE+ Ports
Plug and Play
PoE 120 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 18
Number of 1GE combo ports
Number of 10/100BASE-T ports
  • 16
  • 16
  • 16
  • 120 W
  • 5.3 Mpps
  • 7.2 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
