RG-ES106F-P - 1
RG-ES106F-P - 2
RG-ES106F-P - 3
RG-ES106F-P - 4
RG-ES106F-P - 5
RG-ES106F-P - 6
RG-ES106F-P - 1
RG-ES106F-P - 2
RG-ES106F-P - 3
RG-ES106F-P - 4
RG-ES106F-P - 5
RG-ES106F-P - 6
Compare
RG-ES106F-P
6-Port 10/100 Mbps Unmanaged Switch with 4 PoE+ Ports
RG-ES106F-P, 6-Port 10/100 Mbps Unmanaged Switch with 4 PoE+ Ports
Plug and Play
PoE 54 W
3 Years Warranty
Energy Saving
Unmanaged Switch, Which Is Visible on Ruijie Cloud*
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Intelligent PoE Management
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Key Specifications
  • 6
Number of 10/100BASE-T ports
  • 6
  • 54 W
  • 0.8 Mpps
  • 1.2 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
