RG-ES05G-L - 1
RG-ES05G-L - 2
RG-ES05G-L - 3
RG-ES05G-L - 4
RG-ES05G-L - 5
RG-ES05G-L - 6
RG-ES05G-L - 7
RG-ES05G-L - 8
RG-ES05G-L - 9
RG-ES05G-L - 10
RG-ES05G-L - 11
RG-ES05G-L - 12
RG-ES05G-L - 13
RG-ES05G-L - 14
RG-ES05G-L - 15
RG-ES05G-L - 16
RG-ES05G-L - 1
RG-ES05G-L - 2
RG-ES05G-L - 3
RG-ES05G-L - 4
RG-ES05G-L - 5
RG-ES05G-L - 6
RG-ES05G-L - 7
RG-ES05G-L - 8
RG-ES05G-L - 9
RG-ES05G-L - 10
RG-ES05G-L - 11
RG-ES05G-L - 12
RG-ES05G-L - 13
RG-ES05G-L - 14
RG-ES05G-L - 15
RG-ES05G-L - 16
RG-ES05G-L, 5-Port 10/100/1000 Mbps Unmanaged Non-PoE Switch
Home Office, Retails, Cafe, Villa, etc.
  • 5-port 10/100/1000 Mbps unmanaged non-PoE switch
  • Unmanaged switch, which is visible on Ruijie Cloud
  • High network reliability
  • Applicable to various scenarios
RG-ES05G-L
Plug and Play
Fast Ethernet
3 Years Warranty
Energy Saving
Visible on Ruijie Cloud*
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
