RG-ES118GS-P-L - 1
RG-ES118GS-P-L - 2
RG-ES118GS-P-L - 3
RG-ES118GS-P-L - 4
RG-ES118GS-P-L - 5
RG-ES118GS-P-L - 6
RG-ES118GS-P-L - 7
RG-ES118GS-P-L - 8
RG-ES118GS-P-L - 9
RG-ES118GS-P-L - 1
RG-ES118GS-P-L - 2
RG-ES118GS-P-L - 3
RG-ES118GS-P-L - 4
RG-ES118GS-P-L - 5
RG-ES118GS-P-L - 6
RG-ES118GS-P-L - 7
RG-ES118GS-P-L - 8
RG-ES118GS-P-L - 9
RG-ES118GS-P-L, 18-Port 10/100/1000 Mbps Unmanaged PoE Switch
Surveillance, Home Office, Retails, etc.
  • 18-port 10/100/1000 Mbps unmanaged PoE switch
  • Unmanaged switch, which is visible on Ruijie Cloud
  • Intelligent and secure CCTV network
  • Intelligent PoE Management
  • High-quality design
  • Applicable to various scenarios
RG-ES118GS-P-L
18-Port 10/100/1000 Mbps Unmanaged Switch with 16 PoE+ Ports
RG-ES118GS-P-L, 18-Port 10/100/1000 Mbps Unmanaged Switch with 16 PoE+ Ports
Plug and Play
PoE 247 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
