RG-ES118FGS-LP - 1
RG-ES118FGS-LP - 2
RG-ES118FGS-LP - 3
RG-ES118FGS-LP - 4
RG-ES118FGS-LP - 5
RG-ES118FGS-LP - 6
RG-ES118FGS-LP - 7
RG-ES118FGS-LP - 8
RG-ES118FGS-LP - 1
RG-ES118FGS-LP - 2
RG-ES118FGS-LP - 3
RG-ES118FGS-LP - 4
RG-ES118FGS-LP - 5
RG-ES118FGS-LP - 6
RG-ES118FGS-LP - 7
RG-ES118FGS-LP - 8
RG-ES118FGS-LP, 16-Port 10/100 Mbps with 2-Port Gigabit Unmanaged PoE Switch
Surveillance, Home Office, Retails etc.
  • 16-port 10/100 Mbps with 2-port gigabit unmanaged PoE switch
  • Unmanaged switch, which is visible on Ruijie Cloud
  • Intelligent and secure CCTV network
  • Intelligent PoE Management
  • High-quality design
  • Applicable to various scenarios
RG-ES118FGS-LP
16-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 16 PoE+ Ports
RG-ES118FGS-LP, 16-Port 10/100 Mbps, 2-Port Gigabit Unmanaged Switch with 16 PoE+ Ports
Plug and Play
PoE 120 W
3 Years Warranty
Energy Saving
Intelligent and Secure CCTV Network
Network
PoE Auto
Recovery
250 m (820.21 ft)
Transmission Distance
Flexible
Extend mode
Higher Security
Fit for various powered devices Up to 30 W
Better Quality Design
  • Home Office
  • Cafe
  • Retail
  • Outdoor Surveillance
Comparison
Downlink Ports
Uplink Ports
PoE/PoE+ ports
Max. PoE budget
Layer Type
MAC address table
Weight (With package)
Auto MDI/MDIX
PoE Watchdog Interval
Reset Button
Flow Control
Port Isolation
Power Consumption
Power Supplies
Surge Protection
Operating Temperature
Storage Temperature
Operating Humidity
Storage Humidity
Certificate
