RG-RAP62-OD - 1
RG-RAP62-OD - 2
RG-RAP62-OD - 3
RG-RAP62-OD - 4
RG-RAP62-OD - 5
RG-RAP62-OD - 6
RG-RAP62-OD - 7
RG-RAP62-OD - 8
RG-RAP62-OD - 9
RG-RAP62-OD - 10
RG-RAP62-OD - 11
RG-RAP62-OD - 12
RG-RAP62-OD - 1
RG-RAP62-OD - 2
RG-RAP62-OD - 3
RG-RAP62-OD - 4
RG-RAP62-OD - 5
RG-RAP62-OD - 6
RG-RAP62-OD - 7
RG-RAP62-OD - 8
RG-RAP62-OD - 9
RG-RAP62-OD - 10
RG-RAP62-OD - 11
RG-RAP62-OD - 12
Compare
RG-RAP62-OD, AX3000 Wi-Fi 6 Indoor/Outdoor Versatile Access Point
Open Dining Area, Corridor Wi-Fi, Backyard, Pool & Jacuzzi
  • AX3000 Versatile Outdoor/Indoor Mesh AP for Villas and Retail Businesses
  • Wall or Pole Mounting to Fit in Any Location
  • IP65 Weatherproof Rating, Delivering Consistent Protection and Signal Stability
  • Build-in Antennas for Coverage Where Needed
  • Tailored for Retail Businesses with Reyee Mesh, Standalone Portal, and AI Roaming Features
Small But That Fine Wi-Fi
Small But
That Fine Wi-Fi
AX3000 Wi-Fi 6 Indoor/Outdoor Versatile Access Point AX3000 Wi-Fi 6 Indoor/Outdoor
RG-RAP62-OD
Featuring A Sleek Design for
Deployment Indoors and Outside
  • Fast & Stable Wi-Fi 6 Speeds
    Ideal for Open Space Business
    Outdoor Wi-Fi Coverage
  • More Devices and Wider Coverage
    This is what your house's Wi-Fi
    should be
  • Fast & Stable
    Wi-Fi 6 Speeds
  • More Devices and
    Wider Coverage
Ideal for Open Space Business Outdoor Wi-Fi Coverage
This is what your house's Wi-Fi should be
The Way We Made
Reliable & Long-Range
Wi-Fi for Coverage
The Way We Made Reliable &
Long-Range Wi-Fi for Coverage
Professional build-in antennas equipped with
Enterprise-grade high-gain amplifiers and utilized Wi-Fi
6 technology to make the whole device perform
perfectly in coverage and quality Wi-Fi delivered.
Professional build-in antennas equipped with Enterprise-grade high-gain amplifiers and utilized Wi-Fi 6 technology to make the whole device perform perfectly in coverage and quality Wi-Fi delivered.
  • Reyee Mesh
  • IP65
  • Smart Build-in Antennas
  • Cloud Management
Refined Appearance
Infinite Art Possible, Unleash limited Space
Refined Appearance
limited Space
Consistent Protection, Stable Signal
Weatherproof - Rated as IP65 during Ingress Protection Testing
  • Raining-Proof
    (Within A distance of 2.5 meters)strongly sprayed by water with a flow rate of 12.5±0.625(L/min)
  • Dust-Proof
    Highest Protection to prevent tiny dust into the inside of device
  • Surge-Protection
    4kV Lightning Protection
    15kV ESD Protection
Optimized Features for Street Business
  • Reyee Mesh
  • AP Portal
  • Roaming
  • Self-Organizing Network
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • PoE/PoE+
  • 16 W
  • Wall/Pole
  • IP65
    512 (5 GHz)
