RG-RAP6262 - 1
RG-RAP6262 - 2
RG-RAP6262 - 3
RG-RAP6262 - 4
RG-RAP6262 - 5
RG-RAP6262 - 6
RG-RAP6262 - 7
RG-RAP6262 - 8
RG-RAP6262 - 1
RG-RAP6262 - 2
RG-RAP6262 - 3
RG-RAP6262 - 4
RG-RAP6262 - 5
RG-RAP6262 - 6
RG-RAP6262 - 7
RG-RAP6262 - 8
Compare
RG-RAP6262 Reyee AX3000 High-performance Outdoor Omni-directional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • UFO-style design – perfect blend of high performance and full coverage.
  • Wi-Fi 6 ultra-high-speed.
  • Long-distance deployment with optical ports.
  • IP68 rating, adapting to harsh environments.
  • Easily adding extra outdoor Wi-Fi with Reyee mesh.
Perfect Blend of High Performance and Full Coverage
  • Wi-Fi 6
    AX3000
  • Omni-directional
    Antennas
  • Optical
  • Reyee Mesh
    Technology
  • Free Cloud
Wi-Fi 6 Ultra-High-Speed
With a revolutionary combination of OFDMA and 1024QAM, 802.11ax standard, and 160 MHz band,
the RG-RAP6262 delivers a rate as high as 2.976 Gbit/s.
Long-Distance Deployment
With gigabit optical ports, the RG-RAP6262 supports up to 20 km
transmission from a data center with single-mode fibers.
Coping with Harsh Environments
The RG-RAP6262 is completely sealed, waterproof, dustproof, moisture-proof, and flame-retardant,
and uses wind erosion protection, a wide temperature range, and 4 kV surge protection.
  • IP68
    Rating
  • 4 kV Lighting
    Protection
  • Wind Erosion
    Protection
  • -30°C to +65°C
    Flame-Retardant
Omni-directional Coverage with a Wide Range
Five built-in high-gain antennas, and full coverage with a radius of 100 meters at 2.4 GHz and 300 meters at 5 GHz*.
*The maximum range of Wi-Fi coverage is calculated based on field tests. The transmission range may vary depending on the environment, receiving device, and other items.
Easily Adding Extra Outdoor Wi-Fi with Reyee Mesh
No cabling, and ease of use
Easy Installation
Rack-separated mounting design, easy installation, and plastic cable ties replaced by the iron hoop.
Cloud Makes Your Business Easy
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • Ø230 mm x 195 mm (Ø9.06 in. x 7.68 in.) (spherical device, excluding the mounting bracket)
  • ≤ 1.4 kg (3.09 lbs.) (without packaging materials)
    ● PoE/PoE+
  • 24 W
  • Wall/Pole
  • IP68
    512 (5 GHz)
Access Point
Power Adapter 0
Quick Start Guide 1
Cat5E UTP Cable 0
Mounting Bracket 1
Rack-mount Brackets 1
Screw  2 × M8×20
4 × M8×60
Warranty Card 1
Package Weight 4.62 kg
Package Dimension (w x d x h)  475 mm x 305 mm x 270 mm
