RG-RAP6260(G)
RG-RAP6260(G) AX1800 Wi-Fi 6 Dual Band Gigabit Outdoor Access Point
Overview
Specification
Technical Library
RG-RAP6260(G) is one of the wireless products fully developed by Ruijie Reyee. The device supports 802.3at PoE In power supply. With concurrent 2.4GHz and 5GHz, the AP supports dual-band dual-stream MIMO technology, providing 574Mbps at 2.4G, and 1201Mbps at 5G.
RG-RAP6260(G) supports Reyee Mesh, which allows users easily expand extra Wi-Fi in outdoor place. Less wiring, more relaxing.
RG-RAP6260(G) applies for IP68 protection on the outer shell design, which is suitable in the outdoor environment and voids the influence from the extreme condition. The device meets the demanding requirements, such as able to perform under ultra-cold and humid weather. This reduces the difficulty of installation and maintenance. RG-RAP6260(G) supports Power over Ethernet remote mode, which is highly suitable for many scenarios such as education, government, medical, finance, business.
More+
Reyee New Generation Outdoor
Access Point
RG-RAP6260(G)
802.11AX
Standard
Gigabit
SFP Port
Recommended
Concurrent Users
Water/Dust
Proof
Surge
Protection
Highest
Flame-retardant Level
Operating
Angle Flexible
Adjustment
L3 Roaming
Self-Organizing
Network
Mobile APP
Remote
Maintenance
Move Wi-Fi 6 to Outdoors
RG-RAP6260(G) Compliant with the 802.11AX Wi-Fi 6 Standard
Allow 100 Users Access Concurrently
to Internet
OFDMA
MU-MIMO
Outdoor Wireless Can Also be Faster
AX1800 standard, 1200Mbps speed on 5GHz
Even at Outdoors, the Wi-Fi Speed can also be better
Square
Scenic spot
Station
School
Market
Construction Site
Support Extra-Distance Access
Point Deployment
With gigabit SFP port, the device supports up to 20km
transmission from datacenter with single mode fiber
No Worries About Harsh Environment
Industrial-Level Design, More Reliable
IP68 Level
Protection
Surge Protection
6000V
Flame-retardant
V0 Highest Level
Wide Temperature
-40°C ~ 65°C
IP68 Level
Protection
Surge Protection
6000V
Flame-retardant
V0 Highest Level
Wide Temperature
-40°C ~ 65°C
Signal Interference Filtered,
Transmission More Stabilized
Equipped with high quality FBAR filter, which can effectively suppress and filter the interference from carrier cell base station and Bluetooth devices etc.
With high quality antenna, the receiving sensitivity is further optimized, thereby improves transmission quality.
Layer 3 Roaming,
Ensure Service Always Online
With layer 3 networking, when a user accesses the Internet across the layer 3 network, the terminal can perform a fast and smooth roaming switchover, ensuring service continuity
4S Automobile Store
Self-Organizing Network Gets
All Devices Online Easily
Too many APs? Gateway, switch configuration too complex? Don't worry, SON can help you easily complete the whole network equipment setup.
From Setup, Debug, Delivery, to Maintenance
Whole Network Cloud Management
RG-RAP6260(G)
