RG-RAP6260(H)-D - 1
RG-RAP6260(H)-D - 2
RG-RAP6260(H)-D - 3
RG-RAP6260(H)-D - 4
RG-RAP6260(H)-D - 5
RG-RAP6260(H)-D - 6
RG-RAP6260(H)-D - 7
RG-RAP6260(H)-D - 8
RG-RAP6260(H)-D - 1
RG-RAP6260(H)-D - 2
RG-RAP6260(H)-D - 3
RG-RAP6260(H)-D - 4
RG-RAP6260(H)-D - 5
RG-RAP6260(H)-D - 6
RG-RAP6260(H)-D - 7
RG-RAP6260(H)-D - 8
Compare
RG-RAP6260(H)-D Reyee AX6000 High-density Outdoor Directional Access Point
Pool, Parking, Beach, Warehouse, Traffic Station, Plaza, Playground, Stadium, Park, etc.
  • Ultra-fast 5.95 Gbit/s outdoor Wi-Fi 6, best-in-class Wi-Fi performance
  • Easily adding extra outdoor Wi-Fi with Reyee mesh
  • Long-distance deployment with optical ports
  • IP68 rating, adapting to harsh environments
  • Internet access with 2.5 Gbit/s uplink
Build Ultra-fast and High-density Outdoor Wi-Fi 6
  • Wi-Fi 6
    AX6000
  • High Density
    Access
  • 2.5GE Port
    SFP Port
  • Reyee Mesh
    Technology
  • Free Cloud
Best-in-class Wi-Fi Performance
With a revolutionary combination of OFDMA and 1024QAM, the latest 802.11ax standard, the 160MHz band,
and dual band 4x4 MU-MIMO, RG-RAP6260(H) wireless aggregation rate reaches 5.95Gbps.
Easily Add Extra Outdoor Wi-Fi with Reyee Mesh
Less wiring, more relaxing
Support Extra-Distance Access Point Deployment
With gigabit SFP port, the device supports up to 20km
transmission from datacenter with single mode fiber
Boost Your Internet Speed with 2.5Gbps Uplink
Rock-solid in Harsh Environments
Adopts completely sealed, waterproof, dustproof, moisture proof and flame-retardant,
wind erosion protection,wide temperature range, and 4kV surge protection design.
  • IP68
    Protection
  • 4kV Lighting
    Protection
  • Wind Erosion
    Protection
  • -40℃~65℃
    Flame-Retardant
Directional Coverage with Long Range
Built-in high gain antennas, supports full coverage.
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Key Specifications
  • Outdoor AP
    8 spatial streams
    ● 2.4 GHz: 4 x 4, MU-MIMO
    ● 5 GHz: 4 x 4, MU-MIMO
  • 5950 Mbps
  • 4803 Mbps
  • 1147 Mbps
  • 2.4 GHz: 4 built-in directional antennas
    5 GHz: 4 built-in directional antennas
  • 300 mm x 300 mm x 75.5 mm (11.81 in. x 11.81 in. x 2.97 in.) (excluding the mounting bracket)
  • ≤ 3.5 kg (7.72 lbs.) (without packaging materials)
    ● PoE+/PoE++
  • Yes, one DC power connector (48 V, 1 A)
  • 40 W
  • Wall/Pole
  • IP68
    512 (5 GHz)
