RG-RAP2260(H) - 1
RG-RAP2260(H) - 2
RG-RAP2260(H) - 3
RG-RAP2260(H) - 4
RG-RAP2260(H) - 5
RG-RAP2260(H) - 6
RG-RAP2260(H) - 7
RG-RAP2260(H) - 8
RG-RAP2260(H) - 9
RG-RAP2260(H) - 1
RG-RAP2260(H) - 2
RG-RAP2260(H) - 3
RG-RAP2260(H) - 4
RG-RAP2260(H) - 5
RG-RAP2260(H) - 6
RG-RAP2260(H) - 7
RG-RAP2260(H) - 8
RG-RAP2260(H) - 9
Compare
RG-RAP2260(H) Reyee Wi-Fi 6 AX6000 High-density Multi-G Ceiling Access Point
Hospitality, Restaurant, Shopping Mall, Meeting Room, Railway Station, etc.
  • Build ultra-fast and high-density Wi-Fi with 5.95Gbps throughput.
  • Client connections over 500, higher practical performance as well.
  • Boost Internet speed with 5Gbps uplink for the future.
  • Easily install extra AP with Reyee Mesh technology.
  • Support standalone captive portal, easy to enable Wi-Fi authentication.
Build Ultra-Fast Wi-Fi Network for the Future.
InterfaceInstallation
  • AX6000
    Wi-Fi 6
  • 4x4
    MU-MIMO
  • Dual 2.5 Gbps
    Wired Uplink
  • Reyee Mesh
    Technology
  • Free Cloud
  • AX6000
    Wi-Fi 6
  • 4x4
    MU-MIMO
  • Dual 2.5 Gbps
    Wired Uplink
  • Reyee Mesh
    Technology
  • Free Cloud
Better Multi-User Experience in High-density Scenarios
Performance upgrade, 500+ client connections.
Boost Your Internet Speed with 5 Gbit/s Uplink
Integrated dual 2.5GE uplinks, building a network for the future.
Easy Installation of an Extra AP with Reyee Mesh
No cabling, and ease of use.
More Flexible Wi-Fi Authentication
Standalone captive portal, easy to enable Wi-Fi authentication based on Ruijie Cloud only.*
*The new firmware to be released in 2023 Q2 will provide standalone portal authentication.
Cloud Makes Your Business Easy
  • Cloud portal authentication
Key Specifications
  • Ceiling AP
    8 spatial streams
    ● 2.4 GHz: 4 x 4, MU-MIMO
    ● 5 GHz: 4 x 4, MU-MIMO
  • 5950 Mbps
  • 4803 Mbps
  • 1147 Mbps
  • 2.4 GHz: 4 built-in omnidirectional antennas
  • 230 mm x 230 mm x 49.5 mm (9.06 in. x 9.06 in. x 1.95 in.) (excluding the mounting bracket)
  • ≤ 1.36 kg (3.00 lbs.) (without packaging materials)
    ● PoE+/PoE++
  • Yes, one DC power connector (48 V, 1 A)
  • 40 W
  • Ceiling/Wall
    512 (5 GHz)
Access Point
User Manual
Certificate of Quality 4
Screws and Wall Anchors 1
Mounting Bracket 1
Package Weight  1.79 kg
Package Dimension (w x d x h)  Key to Security Lock 1
