RG-RAP2260(E) - 1
RG-RAP2260(E) - 2
RG-RAP2260(E) - 3
RG-RAP2260(E) - 4
RG-RAP2260(E) - 5
RG-RAP2260(E) - 6
RG-RAP2260(E) - 1
RG-RAP2260(E) - 2
RG-RAP2260(E) - 3
RG-RAP2260(E) - 4
RG-RAP2260(E) - 5
RG-RAP2260(E) - 6
Compare
RG-RAP2260(E) Reyee Wi-Fi 6 AX3200 Multi-G Ceiling Access Point
Hospitality, Restaurant, Shopping Mall, Meeting Room, Railway Station, etc.
  • Build ultra-high performance network with 3202Mbps wireless throughput.
  • Client connections over 500, provide higher practical performance for users as well.
  • Boost Internet speed with 2.5Gbps uplink.
  • Easily install extra AP with Reyee Mesh technology.
  • Set up Wi-Fi 6 network in 3 minutes with Ruijie Cloud APP.
Easily Build Your Ultra-High Performance Network
in High-Density Environment
Interface
AX3200
Wi-Fi 6
2.5 Gbps
Wired Uplink
4x4
MU-MIMO
Reyee Mesh
Technology
Free Cloud
Provide Higher Practical Performance for Users
Reyee RG-RAP2260(E) AP’s 2.4GHz and 5GHz radio outperformed the Ubiquiti U6-LR dramatically
in both the transmit and receive tests.*
Average
Throughput (Mbps)
AP Receive Performance (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Source: Tolly, October 2021
Figure 1
Average
Throughput (Mbps)
Ubiquiti U6-LR
Reyee RG-RAP2260(E)
Figure 2
Better Multi-User Experience in High-Density Scenarios
Performance upgraded, support client connections over 500.
Boost Your Internet Speed with 2.5Gbps Uplink
Build network for future, protect your investments.
Wireless 3200 Mbps
Wired 2500 Mbps
Easily Install Extra AP with Reyee Mesh
Less wiring, more relaxing.
Easily Set Up Your Wi-Fi 6 Network in 3 Minutes
With SON (Self-organizing Network) technology, easily set up a whole Wi-Fi network by Ruijie Cloud APP.
  • Self-organizing network
  • Scenario based configuration
  • Cloud portal authentication
Key Specifications
  • Ceiling AP
    8 spatial streams
    ● 2.4 GHz: 4 x 4, MIMO
    ● 5 GHz: 4 x 4, MU-MIMO
  • 3201 Mbps
  • 2401 Mbps
  • 800 Mbps
  • 2.4 GHz: 4 built-in omnidirectional antennas
  • 220 mm x 220 mm x 35 mm (8.66 in. x 8.66 in. x 1.38 in.) (excluding the mounting bracket)
    ● PoE+
  • Yes, one DC power connector (12 V, 2.5 A)
  • 25.4 W
  • Ceiling/Wall
  • IP41
    256 (5 GHz)
Compare Models
    Length: 10 mm (0.39 in.)
PoE In standard
  • ● IEEE 802.3af (PoE)
    Note: Radio transmission and reception is limited to 1T1R at 2.4 GHz and 5 GHz.
    ● IEEE 802.3at (PoE+)
  • 30 W
  • IP41
  • 208 mm x 208 mm x 40 mm (8.19 in. x 8.19 in. x 1.57 in.) (excluding the mounting bracket)
  • ≤ 0.75 kg (1.65 lbs.) (without packaging materials)
dsadsadsada
Applications
PoE In standard
  • 30 W
  • IP41
Mounting Bracket
Cross Pan Head Screw 2
Expansion Anchor 2
Quick Start Guide 1
Warranty Card 1
Package Weight  1.43kg
Package Dimension (w x d x h)  290 mm x 290 mm x 71 mm
Additional Information
PoE In standard
  • 30 W
  • IP41
