RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
RG-EG210G-E - 4
RG-EG210G-E - 5
RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
RG-EG210G-E - 4
RG-EG210G-E - 5
Compare
RG-EG210G-E Reyee 10-Port Gigabit Cloud Managed Router
Office, Hotel, School, Retail, CCTV, Home, etc.
  • 1Gbps performance, user-friendly configuration and easy to use.
  • High reliability and load balancing through WAN ports.
  • Easy to block unwanted applications with automatically updating library.
  • Customized portal page, what you see is what you get (WYSIWYG).
  • Secure access to internal devices remotely.
Interface
Multi-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
Configuration,
Easy to Use
Advanced functions can be also
easily configured through Ruijie Reyee App.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updating app library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access
to Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Key Specifications
  • 10
Number of fixed LAN ports
  • 6
Number of fixed WAN ports
  • 16 MB
RAM
  • 256 MB
  • 2.35 kg (5.18 lbs)
  • Rack
  • 200
Throughput
  • 1000 Mbps
Device  RG-EG105G V2 RG-EG105G-P V2 RG-EG210G-P RG-EG210G-E
Foot Pad 4 4 4 4
Power Adapter 1 1 1 -
Mounting bracket - - - 2
M4x8 Screws - - - 6
Power cord - - 1 1
Power cord retention clip - - - 1
Quick Start Guide 1 1 1 1
Warranty Card 1 1 1 1
Package Weight 0.9 kg  1.3 kg  1.5 kg 3.25 kg
Package Dimension (w x d x h) 537 mm x 283 mm x 348 mm 533 mm x 279 mm x 340 mm 598 mm x 350 mm x 330 mm 560 mm x 470 mm x 380 mm
