RG-EG105G-P V2 - 1
RG-EG105G-P V2 - 2
RG-EG105G-P V2 - 3
RG-EG105G-P V2 - 4
RG-EG105G-P V2 - 5
RG-EG105G-P V2 - 6
RG-EG105G-P V2 - 7
RG-EG105G-P V2 - 8
RG-EG105G-P V2 - 1
RG-EG105G-P V2 - 2
RG-EG105G-P V2 - 3
RG-EG105G-P V2 - 4
RG-EG105G-P V2 - 5
RG-EG105G-P V2 - 6
RG-EG105G-P V2 - 7
RG-EG105G-P V2 - 8
Compare
RG-EG105G-P V2 Reyee Cloud Managed PoE Router
Office, Hotel, School, Retail, CCTV, Home, etc.
  • User-friendly configuration and easy to use.
  • High reliability and load balancing through WAN ports.
  • Easy to block unwanted applications with automatically updating library.
  • Customized portal page, what you see is what you get (WYSIWYG).
  • Secure access to internal devices remotely.
Interface
Dual-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
configuration,
and Easy to Use
EAdvanced functions can be also
easily configured through Ruijie Reyee APP.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updated APP library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access to
Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Key Specifications
  • 5
Number of fixed LAN ports
  • 3
Number of fixed WAN ports
  • 16 MB
RAM
  • 128 MB
  • 54 W
  • 206.5 mm x 108.5 mm x 28 mm (8.13 in. x 4.27 in. x 1.1 in.)
  • 0.84 kg (1.85 lbs)
  • Desk
  • 100
Throughput
  • 600 Mbps
Device  RG-EG105G V2 RG-EG105G-P V2 RG-EG210G-P RG-EG210G-E
Foot Pad 4 4 4 4
Power Adapter 1 1 1 -
Mounting bracket - - - 2
M4x8 Screws - - - 6
Power cord - - 1 1
Power cord retention clip - - - 1
Quick Start Guide 1 1 1 1
Warranty Card 1 1 1 1
Package Weight 0.9 kg  1.3 kg  1.5 kg 3.25 kg
Package Dimension (w x d x h) 537 mm x 283 mm x 348 mm 533 mm x 279 mm x 340 mm 598 mm x 350 mm x 330 mm 560 mm x 470 mm x 380 mm
