RG-EG105G V2 - 1
RG-EG105G V2 - 2
RG-EG105G V2 - 3
RG-EG105G V2 - 4
RG-EG105G V2 - 5
RG-EG105G V2 - 1
RG-EG105G V2 - 2
RG-EG105G V2 - 3
RG-EG105G V2 - 4
RG-EG105G V2 - 5
Compare
RG-EG105G V2 Reyee Cloud Managed Router
Office, Hotel, School, Retail, CCTV, Home, etc.
  • User-friendly configuration and easy to use.
  • High reliability and load balancing through WAN ports.
  • Easy to block unwanted applications with automatically updating library.
  • Customized portal page, what you see is what you get (WYSIWYG).
  • Secure access to internal devices remotely.
Powerful features for small-sized networks, and simplified configuration
Interface
Dual WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly Configuration
and Easy to Use
Advanced functions can be also
easily configured through Ruijie Reyee APP.
Intelligent load balancing and link redundancy between multiple WAN ports
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updating app library, maintenance-free
Customized Portal Page,
What You See is What You Get
Secure Access
to Internal Devices Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Key Specifications
  • 5
Number of fixed LAN ports
  • 3
Number of fixed WAN ports
  • 16 MB
RAM
  • 128 MB
  • 206.5 mm x 108.5 mm x 28 mm (8.13 in. x 4.27 in. x 1.1 in.)
  • 0.84 kg (1.85 lbs)
  • Desk
  • 100
Throughput
  • 600 Mbps
Device  RG-EG105G V2 RG-EG105G-P V2 RG-EG210G-P RG-EG210G-E
Foot Pad 4 4 4 4
Power Adapter 1 1 1 -
Mounting bracket - - - 2
M4x8 Screws - - - 6
Power cord - - 1 1
Power cord retention clip - - - 1
Quick Start Guide 1 1 1 1
Warranty Card 1 1 1 1
Package Weight 0.9 kg  1.3 kg  1.5 kg 3.25 kg
Package Dimension (w x d x h) 537 mm x 283 mm x 348 mm 533 mm x 279 mm x 340 mm 598 mm x 350 mm x 330 mm 560 mm x 470 mm x 380 mm
