RG-EW7200BE PRO - 1
RG-EW7200BE PRO - 2
RG-EW7200BE PRO - 3
RG-EW7200BE PRO - 4
RG-EW7200BE PRO - 5
RG-EW7200BE PRO - 6
RG-EW7200BE PRO - 1
RG-EW7200BE PRO - 2
RG-EW7200BE PRO - 3
RG-EW7200BE PRO - 4
RG-EW7200BE PRO - 5
RG-EW7200BE PRO - 6
Compare
RG-EW7200BE PRO, Cloud-Managed 7200 Mbps Wi-Fi 7 Gaming Router
Home environments (e.g., villas, large apartments, bungalows), small offices, retail shops, etc.
  • Unmatched Speed with Wi-Fi 7
  • 2 x 2.5 Gbps WAN ports
  • 3 x 2.5 Gbps and 4 x 1 Gbps LAN ports
  • 9 antennas and 9 FEMs
  • Enterprise-grade flagship chip
  • Advanced gaming features
  • Exclusive Reyee Mesh feature
  • Ruijie Reyee App, manage your home network at your fingertips
  • Ruijie will provide security updates for the RG-EW7200BE PRO in Singapore until September 15, 2027, and may extend support beyond this date.
Make Barriers None
Make Distance Zero
Introducing the RG-EW7200BE PRO, a cutting-edge router offering speeds up to 7200 Mbps.
Featuring MLO and MRU for superior performance, it delivers exceptional coverage and stability. Experience
unparalleled networking performance with the RG-EW7200BE PRO.
  • BE7200
    With speeds up to 7200 Mbps, the RG-EW7200BE PRO delivers seamless gaming and smooth HD streaming for an exceptional online experience.
  • Multi-Link Operation
    Advanced MLO technology allows devices to simultaneously use multiple bands for faster and more stable wireless data transmission.
  • Outstanding Signal
    Penetration
    9 antennas and 9 FEMs ensure strong signal penetration.
  • Advanced Gaming
    Exclusive 2.5 Gbps gaming ports and gaming Wi-Fi ensure a smooth gaming experience.
  • 5 x 2.5 Gbps & 4 x 1 Gbps
    Unleash the power of Gigabit Internet.
  • Recommended Users: 96
    Easily connect all your smart home devices.
Make Barriers None, Make Distance Zero
Make Barriers None,
Make Distance Zero
With 9 antennas and 9 FEMs, the RG-EW7200BE PRO penetrates three walls and eliminates coverage holes, ensuring strong and reliable coverage
that makes barriers disappear and distances negligible.
Build an Ideal Network with
5 x 2.5 Gbps & 4 x 1 Gbps Ports
  • Dual-WAN Aggregation
    Dual-WAN aggregation combines multiple internet connections to deliver wired bandwidth exceeding 4.2 Gbps.
  • Load Balancing
    Dual-WAN load balancing optimizes network traffic distribution across two ISP connections for enhanced performance.
  • Dual-Line Backup
    In primary/backup mode, the backup connection automatically takes over if the primary fails, ensuring continuous Internet access.
  • Dual-LAN Aggregation
    Dual-LAN aggregation allows wired devices to achieve speeds of over 4.2 Gbps, significantly enhancing data transfer rates for a more efficient network.
USB 3.0 Port
The USB 3.0 port on the RG-EW7200BE PRO supports fast file sharing through external storage devices, allowing multiple devices on the network to access and download files easily—perfect for home and office environments.
Reyee Mesh, Easy Network Expansion
Reyee Mesh,
With Reyee Mesh, you can say goodbye to coverage holes. Reyee Mesh supports the interconnection of all Reyee Wi-Fi 5,
Wi-Fi 6 and Wi-FI 7 home routers to set up a network that ensures seamless roaming and unified management.
Experience Internet Freedom
The Ruijie Reyee APP provides incredible advanced features, allowing you to remotely manage your network at any time.
  • Network Status Monitoring
    Monitor your router's status in real-time, keeping you updated on connection status, bandwidth usage, and network issues.
  • Online Device Monitoring
    Monitor the online status of devices connected to your router with ease.
  • Remote Reboot
    Experiencing network issues? Try remote rebooting for a quick fix.
  • Password Changing
    Worried about Wi-Fi security? Protect your network with the password management feature.
Key Specifications
  • 9 x external antennas
Antenna gain (2.4 GHz)
  • 4 dBi
Antenna gain (5 GHz)
  • 5 dBi
FEM
  • 2.4GHz: iPA
    5GHz: EPA
Max. Wi-Fi Speed
  • 2.4 GHz, 1377 Mbps
    5 GHz, 5765 Mbps
Wi-Fi standard
  • Wi-Fi 7 (IEEE 802.11be)
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
  • 128 (2.4 GHz)
    256 (5 GHz)
  • 16 (2.4 GHz)
    64 (5 GHz)
