RG-EW6000GX - 1
RG-EW6000GX - 2
RG-EW6000GX - 3
RG-EW6000GX - 4
RG-EW6000GX - 5
RG-EW6000GX - 1
RG-EW6000GX - 2
RG-EW6000GX - 3
RG-EW6000GX - 4
RG-EW6000GX - 5
Compare
RG-EW6000GX 6000M Wi-Fi 6 Mesh Router with 2.5G Port
Home Scenarios (Including Villa, Large-sized Apartment, Bungalow), SOHO Office, Small Shop, etc.
  • Ultra-high-speed with Wi-Fi 6 standard (160MHz)
  • Quad-core enterprise level chipset
  • Max clients up to 384
  • Gaming port
  • Strong signals received
  • Cloud-based Management
  • Exclusive Reyee mesh providing full-space-coverage Wi-Fi solution
Full-Power
RG-EW6000GX
Steady as Dune, Fast as Wind
RG-EW6000GX with 160 MHz Channel Bandwidth & 6000 Mbps Network Speed. Unleash Full-Power Wi-Fi 6 for Accelerated Digital Life.
  • 2.5 Gbps Port
  • Enterprise-Level
    Quad-Core Chipset
  • 8 x Antennas
  • Gaming Mode
Select Your Networking with 1 x 2.5 Gbps WAN/LAN Port &
1 x 1 Gbps WAN/LAN Port & 3 x 1 Gbps LAN Ports
  • Dual-WAN Aggregation
    In dual-WAN aggregation, two Internet connections can achieve a bandwidth exceeding 1.6 Gbps, optimizing network traffic distribution across two ISPs.
  • Dual-LAN Aggregation
    Dual-LAN aggregation allows wired devices to achieve speeds exceeding 1.6 Gbps, significantly supporting high-speed LAN transmission. The RG-EW6000GX is a good helper for vloggers, video creators, video studios.
  • Gaming Port
    Enable Game Turbo by connecting your computer to the gaming port—prioritizing gaming and critical apps for smooth POS, conferencing, and live streaming. Discover even more features!
Supported by Enterprise-Level 2.0 GHz Quad-Core CPU Chipset
Enjoy better stability under heavy load.
The RG-EW6000GX demonstrates more stable network performance with multiple connections.
Support for Concurrent Connections of Multiple Clients
With MU-MIMO technology, the EW6000GX features 8 spatial streams (2.4 GHz: 4x4,
5 GHz: 4x4), doubles device capacity, and allows for fast and simultaneous connections of different clients without delays.
*The data from Ruijie lab. Actual results may vary.
Deliver Powerful Signals, Experience “Wall-less” Freedom
8 antennas
Eliminating coverage holes with strong wall-penetration. Two walls can be penetrated effortlessly.*
*The data is obtained under the laboratory condition.
Wi-Fi Solutions, Ensuring Seamless Roaming and Full Coverage
Amazed by Reyee Mesh
Manage Your Home Network at Fingertips
Ruijie Reyee App provides incredible advanced features, allowing you to remotely manage your network at any time.
  • Network Status Monitoring
    Monitor your router's status in real-time, keeping you updated on connection status, bandwidth usage, and network issues.
  • Online Client Monitoring
    Monitor the online status of devices connected to your router with ease.
  • Remote Reboot
    Experiencing network issues? Try remote rebooting for a quick fix.
  • Password Changing
    Worried about Wi-Fi security? Protect your network with the password management feature.
Key Specifications
  • 8 x external antennas
Antenna gain (2.4 GHz)
  • 4.5 dBi
Antenna gain (5 GHz)
  • 5.5 dBi
FEM
  • iPA
Max. Wi-Fi Speed
  • 2.4 GHz, 1147 Mbps
    5 GHz, 4804 Mbps
Wi-Fi standard
  • Wi-Fi 6 (IEEE 802.11ax)
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
  • 128 (2.4 GHz)
    256 (5 GHz)
  • 16 (2.4 GHz)
    64 (5 GHz)
