RG-EW3000GX - 1
RG-EW3000GX - 2
RG-EW3000GX - 3
RG-EW3000GX - 4
RG-EW3000GX - 5
RG-EW3000GX - 6
RG-EW3000GX - 1
RG-EW3000GX - 2
RG-EW3000GX - 3
RG-EW3000GX - 4
RG-EW3000GX - 5
RG-EW3000GX - 6
Compare
RG-EW3000GX 3000M Wi-Fi 6 Dual-WAN Gigabit Router
Home scenarios (e.g. Villa, Large-sized apartment, Bungalow), SOHO office, small shop, etc
  • Next-generation gigabit Wi-Fi 6 standard
  • Dual-WAN aggregation
  • 160 MHz bandwidth
  • Exclusive Reyee mesh providing full-space-coverage Wi-Fi solution
  • Ruijie Reyee App, manage your home network at your fingertips
RG-EW3000GX
Feel the Leap in Speed
Leveraging the advanced Wi-Fi 6 technology,
RG-EW3000GX supports up to 4x more device
capacity and delivers a 3x faster speed than Wi-Fi 5.
  • 5 Gigabit
    Ethernet Ports
  • 5 High-Gain
    Antennas
  • 160 MHz
    Bandwidth
Achieving Ultra-High Speed with 160MHz Bandwidth
160MHz Bandwidth
Surpassing expectations, RG-EW3000GX supports 160MHz bandwidth. Your network can effortlessly achieve a
stable 900+ Mbps ultra-high-speed transmission.
Surpassing expectations, RG-EW3000GX supports 160MHz bandwidth. Your network can effortlessly achieve a stable 900+ Mbps ultra-high-speed transmission
Double WAN Ports,
Double the Speed
With support for dual-gigabit access and the
ability to aggregate bandwidth for a total
throughput of over 1.6 Gbps.
With support for dual-gigabit access and the ability to aggregate bandwidth for a total throughput of over 1.6 Gbps.
  • Load Balancing
  • Link Aggregation
  • Multi-ISP Lines
Cover More, Connect More
Equipped with 5 high-gain antennas, RG-EW3000GX provides full Wi-Fi signal coverage across a
spacious apartment without any coverage hole.
Equipped with 5 high-gain antennas, RG-EW3000GX provides full Wi-Fi signal coverage across a spacious apartment without any coverage hole.
Reyee Mesh, Easy Network Expansion
Expansion
With Reyee Mesh, you do not need to worry about coverage holes anymore. Reyee Mesh supports the interconnection of all
Reyee Wi-Fi 5 and Wi-Fi 6 home routers to set up a network that enables seamless roaming and unified management.
With Reyee Mesh, you do not need to worry about coverage holes anymore. Reyee Mesh supports the interconnection of all Reyee Wi-Fi 5 and Wi-Fi 6 home routers to set up a network that enables seamless roaming and unified management.
Manage Your Home Network at Fingertips
Ruijie Reyee APP provides incredible advanced features, allowing you to remotely manage your network at any time.
  • Network Status Monitoring
    Monitor your router's status in real-time, keeping you updated on connection status, bandwidth usage, and network issues.
  • Online Device Monitoring
    Monitor the online status of devices connected to your router with ease.
  • Remote Reboot
    Experiencing network issues? Try remote rebooting for a quick fix.
  • Password Changing
    Worried about Wi-Fi security? Protect your network with the password management feature.
Key Specifications
  • 5 x external antennas
Antenna gain (2.4 GHz)
  • 4.5 dBi
Antenna gain (5 GHz)
  • 5.5 dBi
FEM
  • iPA
Max. Wi-Fi Speed
  • 2.4 GHz, 573 Mbps
    5 GHz, 2402 Mbps
Wi-Fi standard
  • Wi-Fi 6 (IEEE 802.11ax)
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
    128 (5 GHz)
  • 16 (2.4 GHz)
    64 (5 GHz)
