RG-NBS3100-8GT2SFP - 1
RG-NBS3100-8GT2SFP - 2
RG-NBS3100-8GT2SFP - 3
RG-NBS3100-8GT2SFP - 4
RG-NBS3100-8GT2SFP - 5
RG-NBS3100-8GT2SFP, 10-Port Gigabit Layer 2 Cloud Managed Non-PoE Switch
Enterprise, Hospitality, Factory, Education, Retails etc.
  • 10-Port gigabit Layer 2 managed non-PoE switch, 2 SFP uplink
  • Enterprise-class Quality Ensures High Performance
  • IP Camera Recognition, Unique Value for CCTV Network
  • Multiple Security Policies Protect Your Network
  • Lifetime management on Ruijie Cloud at anytime anywhere
RG-NBS3100-8GT2SFP
10-Port Gigabit Layer 2 Cloud Managed Switch, 2 SFP Uplinks
  • Switching Capacity
    20 Gbps
  • Forwarding Rate
    14.88 Mpps
  • 5 Years
  • PoE Budget
    370W
  • Max. 30W
    on Each Port
  • Surge Protection
    6KV
  • Performance
  • Features
  • Link Aggregation
  • IGMP Snooping
  • VLAN
  • Security
  • Stability
Key Specifications
Product category
Product category
  • 5 years
  • Operating altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.) Storage altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.)
  • 400,000 hours
Number of 10/100BASE-T ports
  • 8
Number of 1GE combo ports
Number of 10GE SFP+ ports
  • 8
Certification and Regulatory Compliance
Safety compliance
  • IEC 62368-1
  • 15 Mpps
  • 20 Gbps(bit/s)
RG-NBS3100-8GT2SFP
RG-NBS3100-8GT2SFP-P
RG-NBS3100-24GT4SFP
RG-NBS3100-24GT4SFP-P
Basic
10/100/1000Base-T ports
24
24
SFP ports
SFP+ ports
PoE/PoE+ ports
FALES
24
Max. PoE budget
125W
370W
Layer Type
Layer 2
Layer 2
Layer 2
Layer 2
20 Gbps
20 Gbps
56 Gbps
56 Gbps
14.88 Mpps
14.88 Mpps
41.67 Mpps
41.67 Mpps
Packet Buffer
4.1 Mbit
4.1 Mbit
4.1 Mbit
4.1 Mbit
MAC address table
8,000
8,000
8,000
8,000
Maximum VLAN Support
4094
4094
4094
4094
260 mm x 120 mm x 43.6 mm
330 mmx 220 mm x 43.6 mm
440 mmx 165 mm x 44 mm
440 mmx 293 mm x 44 mm
Weight (With package)
1.2 kg
2 kg
2.4 kg
4.5 kg
> 200,000
> 200,000
> 200,000
> 200,000
5 Years
5 Years
5 Years
5 Years
Layer 2 Features
Jumbo Frame
9216
9216
9216
9216
Flow Control
STP (IEEE 802.1d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
Port Fast
BPDU Guard
Errdisable Recovery
Max. Aggregation Group
Max. Member per Group
Many-to-One Mirroring
VLAN Range
1-4094
1-4094
1-4094
1-4094
Port-based VLAN
MAC-based VLAN
IP-based VLAN
LLDP / LLDP-MED
Cable Testing
IGMP Snooping v1/v2/v3
Software Features
Ping
Traceroute
ACL Entries
1200
1200
1200
1200
IP Standard ACL
MAC-based Extended ACL
IP-based Extended ACL
Web Management
Management IP
10.44.77.200
HTTP/HTTPS
Camera Recognition
Loop Prevention
Loop Notification
PoE Usage Alarm
Protection Port
IP Source Guard
Anti-ARP Spoofing
DHCP Snooping
DHCP Client
Physical Features
Reset Button
Front
Front
Front
Front
Cable Hot-swappable
Power Supply Slot
Power adpater
Single, fixed power supply
Power Supplies
100 - 240V AC, 1A
100 - 240V AC, 2A
100 - 240V AC, 0.6A
100 - 240V AC, 6A
Power Consumption
≤ 8W
≤ 145W
≤ 21W
≤ 443W
EEE
Airflow
Left-to-Right
Fan Adaptive Speed Adjustment
Acoustic Noise
Noiseless
Noiseless
Noiseless
< 45dB
Operating Temperature
0°C to 50°C (32°F to 122°F)
Storage Temperature
Operating Humidity
10% to 90% RH
Storage Humidity
5% to 95% RH
Port Surge
6 kV
Operating Altitude (meters)
-500 to 5000
Certificate
CE, RoHS
Copyright ©2000-2022 Ruijie Networks Co., Ltd. All rights reserved.
No part of this document may be reproduced or transmitted in any form or any means without prior written consent of Ruijie Networks Co., Ltd.
Notice
Device RG-NBS3100-8GT2SFP
Mounting Bracket 2
Foot pad 4
Power supply Power cord
Quick Start Guide 1
Warranty Card 1
Accesories Screws * 6
Package Weight 1.2 kg
Package Dimension (w x d x h) 361 mm x 259 mm x 94 mm
