RG-NBS3200-24GT4XS-P - 1
RG-NBS3200-24GT4XS-P - 2
RG-NBS3200-24GT4XS-P, 24-Port Gigabit Layer 2 Cloud Managed PoE Switch, 4 * 10G Uplink
Enterprise, Hospitality, Factory, Education, Retails etc.
  • 24-Port gigabit Layer 2 managed PoE switch, 4 SFP+ uplink
  • Enterprise-class Quality Ensures High Performance
  • IP Camera Recognition, Unique Value for CCTV Network
  • Multiple Security Policies Protect Your Network
  • Lifetime management on Ruijie Cloud at anytime anywhere
24-Port Gigabit Layer 2 Cloud Managed PoE Switch, 4 x SFP Uplinks
  • Switching Capacity
    128 Gbps
  • Forwarding Rate
    96 Mpps
  • 5 Years
  • PoE Budget
    370W
  • Max. 30W
    on Each Port
  • Surge Protection
    6KV
  • Performance
  • Features
  • Link Aggregation
  • IGMP Snooping
  • VLAN
  • Security
  • Stability
Comparison
10/100/1000Base-T ports
SFP/SFP+
PoE/PoE+ ports
Max. PoE budget
MAC address table
Weight (With package)
Jumbo Frame (MTU)
Link Aggregation Group (LAG)
STP/RSTP
Auto Errdisable Recovery
IGMP Snooping v1/v2
EEE
Syslog
Airflow
Port surge
RG-NBS3200-24GT4XS
RG-NBS3200-24SFP/8GT4XS
RG-NBS3200-48GT4XS
RG-NBS3200-48GT4XS-P
Basic
24
24
8 (Combo)
48
48
SFP ports
24
SFP ports
PoE/PoE ports
FALES
24
FALES
FALES
48
Max. PoE budget
370W
370W
Layer Type
Layer 2
Layer 2
Layer 2
Layer 2
Layer 2
128 Gbps
128 Gbps
128 Gbps
176 Gbps
176 Gbps
95.24 Mpps
95.24 Mpps
95.24 Mpps
130.95 Mpps
130.95 Mpps
Packet Buffer
12 Mbit
12 Mbit
12 Mbit
16 Mbit
16 Mbit
MAC address table
Maximum VLAN Support
4094
4094
4094
4094
4094
440 mmx 207.5 mm x 43.6 mm
440 mmx 357.6 mm x 43.6 mm
440 mm x 267.5 mm x 43.6 mm
440 mmx 267.5 mm x 43.6 mm
2.9 kg
4.75 kg
3.35 kg
3.6 kg
5.4 kg
> 200,000
> 200,000
> 200,000
> 200,000
> 200,000
5 Years
5 Years
5 Years
5 Years
5 Years
Layer 2 Features
Jumbo Frame
9216
9216
9216
9216
9216
Flow Control
STP (IEEE 802.1d)
RSTP (IEEE 802.1w)
MSTP (IEEE 802.1s)
Port Fast
BPDU Guard
Errdisable Recovery
Max. Aggregation Group
Max. Member per Group
Many-to-One Mirroring
VLAN Range
1-4094
1-4094
1-4094
1-4094
1-4094
Port-based VLAN
MAC-based VLAN
IP-based VLAN
MAC address Table
16000
16000
16000
16000
16000
LLDP / LLDP-MED
Cable Testing
IGMP Snooping v1/v2/v3
Software Features
Ping
Traceroute
ACL Entries
1900
1900
1900
1900
1900
IP Standard ACL
MAC-based Extended ACL
IP-based Extended ACL
Web Management
Management IP
10.44.77.200
10.44.77.200
10.44.77.200
10.44.77.200
10.44.77.200
HTTP/HTTPS
Camera Recognition
Loop Prevention
Loop Notification
PoE Usage Alarm
Protection Port
IP Source Guard
Anti-ARP Spoofing
DHCP Snooping
DHCP Client
Physical Features
Reset Button
Front
Front
Front
Front
Front
Cable Hot-swappable
Power Supply Slot
Single, fixed power supply
Power Supplies
100 - 240V AC, 1.5A
100 - 240V AC, 6A
100 - 240V AC, 2A
100 - 240V AC, 2A
100 - 240V AC, 7A
Power Consumption
≤ 28W
≤ 432W
≤ 42W
≤ 46W
≤ 448W
EEE
Airflow
Left-to-Rear
Left-to-Right
Left-to-Rear
Left/Right-to-Rear
Left/Right-to-Rear
Fan Adaptive Speed Adjustment
Acoustic Noise
< 45dB
Operating Temperature
0°C to 50°C (32°F to 122°F)
Storage Temperature
Operating Humidity
10% to 90% RH
Storage Humidity
5% to 95% RH
Port Surge
6 kV
Operating Altitude (meters)
-500 to 5000
Certificate
CE, RoHS
Device RG-NBS3200-24GT4XS-P
Mounting Bracket 2
Foot pad 4
Power supply Power cord
Quick Start Guide 1
Warranty Card 1
Accesories Screws * 8
Package Weight 4.75 kg
Package Dimension (w x d x h) 573 mm x 468 mm x 165 mm
