RG-NIS2100-4GT2SFP-HP - 1
RG-NIS2100-4GT2SFP-HP - 2
RG-NIS2100-4GT2SFP-HP - 3
RG-NIS2100-4GT2SFP-HP - 4
RG-NIS2100-4GT2SFP-HP - 5
RG-NIS2100-4GT2SFP-HP - 6
Compare
RG-NIS2100-4GT2SFP-HP, 6-Port Cloud Managed Industrial Switch, with 1 x PoE++ Port, 3 x PoE+ Ports, and 2 x SFP Uplink Ports
CCTV, Factory, Coastal Areas, Dusty Environment, etc.
  • Industrial-Grade Features Ensure Stable Operation Between -40℃ and +75℃
  • IP40 Protection Against 1 mm Solid Particles
  • 6kV Surge Protection Against Voltage Spikes
  • 90W PoE Output: Perfect for High-Power Device
  • Instant ERPS Configuration and Rapid Service Failover Ensure Network Stability
  • Ruijie Cloud: Easy Remote Management Anytime, Anywhere
  • 1 x PoE++ Port
  • 3 x PoE+ Ports
  • 2 x SFP Uplink Ports
  • 5 Years Warranty
Industrial-Grade Features for
Handling Harsh Environmental Challenges
Wide Temperature Range
Full Aluminum Casing Ensures a Wide Operating Temperature Range of -40°C to +75°C
Robust Shield Ensures Network Stability
  • EMC Level 4
    Against Electromagnetic Interference
90W
PoE Output
90W PoE Output
Perfect for
High-Power Device
Small in Size, Ultimate in Convenience
Convenience
    • Compact design,
      perfectly fit into a waterproof outdoor box
    • DIN rail mounting
      support for simplified installation
Compact design, perfectly fit into a waterproof outdoor box
DIN rail mounting support for simplified installation
DIP Switch for Instant ERPS Configuration
Rapid Service Failover Ensures Network Stability
LAN
Self-Organizing
Network
Simplify Setup by
Key Specifications
  • 5 years
  • Default: 108 W
    MAX: 180 W
  • Port 1: 1–2 (+), 3–6 (-), 4–5 (+), 7–8(-)
    Ports 2–4: 1–2 (+), 3–6 (-)
  • 8.9 Mpps
  • 12 Gbps(bit/s)
Device RG-NIS2100-4GT2SFP-HP
Installation Guide 1
Warranty Card 1
Shipping Weight 1.08 kg (2.38 lbs)
