To see the differences, start by clicking "Compare". Your selected products will appear in the
list below,
ready for comparison.
Reyee Product Suggestions
Not sure what to compare? Click “Add Product” and discover similar products recommended for you.
Combine Different Types
group them for
a clear view.
Edit Your List Anytime
products as you
like.
"Compare" box
True Industrial-Grade Specially Designed for Harsh Environments
Three Different Models Meet Various Business Scenario Needs
12-56V DC Power Supply
STP/ RSTP/ SNMP/ ERPS1
8kV ESD Protection
-40°C to +80°C Operating Temperature2
1 Release in November 2023
RG-NIS3100-4GT2SFP-HP
4 PoE+ 2SFP
4 PoE+ 2SFP
4 PoE+ 2SFP
A Must-Have for Coastal Areas
Conquer salt spray corrosion
Stay Cool, Stay Connected
8 kV Protection
The shield against voltage spike
Stand Strong in Dusty Environment
IP40 Protection: Against 1mm intruders in dusty conditions
ERPS ensures network stability
Local Network SON
Tough Environments, Easy Management
Ruijie Cloud: Easy management anytime anywhere
8 kV Protection
ERPS Plug-and-Play
Without complicated configuration
Local Network SON
A Must-Have for Coastal Areas Conquer Salt Spray Corrosion
A precisely applied 50 μm coating effectively isolates against salt spray, maintaining equipment thermal performance and conductivity.
Enhanced Gold Plating Ports
Gold plating thickness on ports from 3 μm to 15 μm against salt spray corrosion.
Specialized Outdoor Powder Coating
Preventing equipment surface damage from salt spray erosion.
Unique Industrial Design Ensures Stable Operation in -40℃ to 80℃
Double Heat Dissipation Surface
360° Cooling, Full Aluminum Alloy Enclosure
True Industrial-Grade Chips
IP40 Protection: Against 1mm intruders in sandstorm conditions
High kV Protection: The Shield Against Voltage Spike
6kV Surge Protection
8kV ESD Protection3
3 Air Discharge
LAN Self-Organizing Network
Ruijie Cloud: Distance No Barrier
12V
DC Input
24V
DC Input
48V
DC Input
Overall
Power Consumption
Power
Supply
RG-NIS3100-8GT4SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-54
RG-NIS3100-8GT2SFP-HP
60W
PoE Power Budget
120W
PoE Power Budget
240W
PoE Power Budget
260W
RG-NIS-PA240-54
60W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
132W
RG-NIS-PA120-54
12V
DC Input
60W
PoE Power Budget
60W
PoE Power Budget
60W
PoE Power Budget
24V
DC Input
120W
PoE Power Budget
120W
PoE Power Budget
120W
PoE Power Budget
48V
DC Input
240W
PoE Power Budget
240W
PoE Power Budget
120W
PoE Power Budget
Overall
Power Consumption
260W
PoE Power Budget
260W
PoE Power Budget
132W
PoE Power Budget
Power
Supply
RG-NIS-PA240-54
RG-NIS-PA240-54
RG-NIS-PA120-54
New power supply models are now available for an enhanced product experience. For End-of-Sale power supply service plan, click here: RG-NIS-PA120-48RG-NIS-PA240-48
Key Specifications
Layer 2
5 years
Number of 1GE combo ports
No
Number of 10GE SFP+ ports
No
Number of 10/100BASE-T ports
No
No
No
No
120 W
1–2 (+), 3–6 (-)
8.93 Mpps
12 Gbps(bit/s)
400,000 hours
-40ºC to +65ºC (-40°F to 149°F) (installed in a sealed cabinet)
-40ºC to +75ºC (-40°F to 167°F) (installed in a fume hood with a ventilation speed of at least 200LFM (Line Feet Minute)) -40ºC to +80ºC (-40°F to 176°F) (installed in a fume hood with a ventilation speed of at least 400LFM (Line Feet Minute))
Operating altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.) Storage altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.)
Service port: ±6 kV for common mode Power connector: ±4 kV for common mode and ±2 kV for differential mode
Interface
Jumbo frame length (MTU)
9216 bytes (global configuration mode)
Broadcast storm control
Device
A power adapter is not included with this product and needs to be purchased separately.
you.
Performance cookies
Essential cookies
