RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
RG-EG210G-E - 1
RG-EG210G-E - 2
RG-EG210G-E - 3
Interface
Multi-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
Configuration,
Easy to Use
Advanced functions can be also
easily configured through Ruijie Reyee App.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updating app library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access
to Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Comparison
WAN Port(s)
LAN Port(s)
LAN/WAN Switchable Port
RAM
Flash
Concurrent User
Max Throughput
Max VLAN
AP Management
WAN Load Balancing
PoE/PoE+
PoE Power Budget,Max.
Captive Portal
PPPoE Server
Max PPPoE Active Client
Smart Flow Control
Application Based Speed Limit
Key Application Priority
User Group Based Speed Limit
Key User Priority
Behavior Management
PPTP
L2TP
IPSec
OpenVPN
Max IPSec Active Tunnels
Max PPTP Active Tunnels
Max L2TP Active Tunnels
Max L2TP Over IPSec Active Tunnels
Max OpenVPN Active Tunnels
Basic Firewall
Power Consumption
Dimensions and Rack Units
Certifications
Device  RG-EG105G V2 RG-EG105G-P V2 RG-EG210G-P RG-EG210G-E
Foot Pad 4 4 4 4
Power Adapter 1 1 1 -
Mounting bracket - - - 2
M4x8 Screws - - - 6
Power cord - - 1 1
Power cord retention clip - - - 1
Quick Start Guide 1 1 1 1
Warranty Card 1 1 1 1
Package Weight 0.9 kg  1.3 kg  1.5 kg 3.25 kg
Package Dimension (w x d x h) 537 mm x 283 mm x 348 mm 533 mm x 279 mm x 340 mm 598 mm x 350 mm x 330 mm 560 mm x 470 mm x 380 mm
