RG-EG105G-P-V3 - 1
RG-EG105G-P-V3 - 2
RG-EG105G-P-V3 - 3
RG-EG105G-P-V3 - 4
RG-EG105G-P-V3 - 5
RG-EG105G-P-V3 - 1
RG-EG105G-P-V3 - 2
RG-EG105G-P-V3 - 3
RG-EG105G-P-V3 - 4
RG-EG105G-P-V3 - 5
RG-EG105G-P-V3 Reyee Cloud Managed PoE Router
Office, Hotel, School, Retail, CCTV, Home, etc.
  • Unified Features with Upgraded Flash Storage
  • User-friendly configuration and easy to use
  • High reliability and load balancing through WAN ports
  • Easy to block unwanted applications with automatically updating library
  • Customized portal page, what you see is what you get (WYSIWYG)
  • Secure access to internal devices remotely
Interface
Dual-WAN
Load Balancing
IPSec, OpenVPN,
PPTP, L2TP, etc.
Captive
Portal
Free Cloud
3-Year
User-friendly
configuration,
and Easy to Use
EAdvanced functions can be also
easily configured through Ruijie Reyee APP.
Seamless
Failover
Aggregated
Bandwidth
Automatic
Setup
Customizable
Link Weight
Automatically updated APP library, maintenance-free.
Customized Portal Page,
What You See is What You Get
Secure Access to
Internal Device Remotely
Cloud,
Make Your
Business
Easy
  • Cloud portal authentication
Comparison
WAN Port(s)
LAN Port(s) (including switchable port)
LAN/WAN Switchable Port
RAM
Flash
Recommended Throughput
Recommended Concurrent Users
Max VLAN
No. of Devices Managed in Router Mode
No. of Devices Managed in AC Mode
PoE/PoE+
PoE Power Budget,Max.
Captive Portal
PPPoE Server
Max PPPoE Active Client
Smart Flow Control
Application Based Speed Limit
Key Application Priority
User Group Based Speed Limit
Key User Priority
Behavior Management
Max IPSec Active Tunnels
Max PPTP Active Tunnels
Max L2TP Active Tunnels
Max L2TP Over IPSec Active Tunnels
Max OpenVPN Active Tunnels
Basic Firewall
SNMP Service
Power Consumption
Dimensions and Rack Units
Certifications
