RG-ES126FGS-LP - 1
RG-ES126FGS-LP - 2
RG-ES126FGS-LP - 3
RG-ES126FGS-LP - 4
RG-ES126FGS-LP - 5
RG-ES126FGS-LP - 6
RG-ES126FGS-LP - 7
RG-ES126FGS-LP - 8
RG-ES126FGS-LP - 1
RG-ES126FGS-LP - 2
RG-ES126FGS-LP - 3
RG-ES126FGS-LP - 4
RG-ES126FGS-LP - 5
RG-ES126FGS-LP - 6
RG-ES126FGS-LP - 7
RG-ES126FGS-LP - 8
RG-ES126FGS-LP
Switch no administrado, con 24 puertos 10/100 Mbps, 2 puertos gigabit y 24 puertos PoE+
RG-ES126FGS-LP. Switch no administrado, con 24 puertos 10/100 Mbps, 2 puertos gigabit y 24 puertos PoE+
Plug and Play
PoE de 180 W
3 años de garantía
Ahorro de energía
y segura
Recuperación
automática de PoE
Distancia de
transmisión de 250 m
Modo ampliado
flexible
Mayor seguridad
Intelligent PoE Management
Diseño de mejor calidad
  • Teletrabajo
  • Cafés
  • Comercios minoristas
  • Vigilancia exterior
  • 26
Number of 1GE combo ports
Number of 10/100BASE-T ports
  • 24
  • 24
  • 24
  • 180 W
  • 6.5 Mpps
  • 8.8 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
