RG-ES08G-L - 1
RG-ES08G-L - 2
RG-ES08G-L - 3
RG-ES08G-L - 4
RG-ES08G-L - 5
RG-ES08G-L - 6
RG-ES08G-L - 7
RG-ES08G-L - 8
RG-ES08G-L - 9
RG-ES08G-L - 10
RG-ES08G-L - 11
RG-ES08G-L - 12
RG-ES08G-L - 13
RG-ES08G-L - 14
RG-ES08G-L - 1
RG-ES08G-L - 2
RG-ES08G-L - 3
RG-ES08G-L - 4
RG-ES08G-L - 5
RG-ES08G-L - 6
RG-ES08G-L - 7
RG-ES08G-L - 8
RG-ES08G-L - 9
RG-ES08G-L - 10
RG-ES08G-L - 11
RG-ES08G-L - 12
RG-ES08G-L - 13
RG-ES08G-L - 14
RG-ES08G-L
Switch no PoE no administrado, con 8 puertos 10/100/1000 Mbps
RG-ES08G-L. Switch no PoE no administrado, con 8 puertos 10/100/1000 Mbps
Plug and Play
Velocidad gigabit
3 años de garantía
Ahorro de energía
Diseño de mejor calidad
  • Teletrabajo
  • Cafés
  • Comercios minoristas
  • Vigilancia exterior
  • 8
  • 8
  • 11.90 Mpps
  • 16 Gbps(bit/s)
  • 0°C to 45°C (32°F to 113°F)
