RG-ES05G
RG-ES05G
Descripción general
Specification
Technical Library
More+
  • Plug and Play Energy Saving
  • Embedded Foot Pads
  • Hidden hanging Holes
Plug and Play & Energy Saving
  • Energy Saving
  • Auto Power Reduction
  • Fansless
  • Noiseless
