RG-RAP1261 - 1
RG-RAP1261 - 2
RG-RAP1261 - 3
RG-RAP1261 - 4
RG-RAP1261 - 1
RG-RAP1261 - 2
RG-RAP1261 - 3
RG-RAP1261 - 4
Compare
RG-RAP1261, Reyee Wi-Fi 6 AX3000 Ultra-Thin Wall Plate Access Point
Hotel, Home, Office, etc.
  • Dual-radio performance, gigabit wireless wall-mounted AP
  • Better experience with Cooling Patent Technology
  • Easy installation, 86mm standard compatible
  • Capable of Reyee Mesh and 802.11K/V/R
  • Powerful Standalone Portal via Ruijie Cloud
AX3000 Dual-Band Ultra-Thin Wall Plate Access Point
RG-RAP1261
  • 8.5mm
    Ultra Thin
  • 2.4G/5G
  • 2x2 MIMO
  • Cooling Patent
  • PoE in 802.3af
  • 8.5mm
    Ultra Thin
  • 2.4G/5G
  • 2x2 MIMO
  • Cooling Patent
  • PoE in 802.3af
Experience Wi-Fi 6, Experience Gigabit Internet
New upgrade to AX3000, Speed Test reaches 950Mbps, delivering the fastest possible internet experience.
Easy Installation, Worldwide Compatible
Unprecedented Thin Design with 8.5mm with Patent Technology,
Thinner, Cooler, Stronger. Averagely reduced 7°C in working mode
Smart AI Roaming Enhances Wireless Experience Anywhere You Go
No matter dynamic or even private IP on gateway WAN port, Securely monitoring the NVR/IPC/Internal Server anytime from anywhere.
Reyee free DDNS
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
  • Wall AP
    ● 5 GHz: 2 x 2, MU-MIMO
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
  • Integrated 2.4 GHz and 5 GHz: 2 built-in omnidirectional antennas
  • 86 mm x 42.4 mm x 86 mm (3.39 in. x 1.67 in. x 3.39 in.)
  • ≤ 0.16 kg (0.35 lbs.) (without packaging materials)
  • PoE/PoE+
  • 10.2 W
  • Junction box
    256 (5 GHz)
