RG-RAP1260 - 1
RG-RAP1260 - 2
RG-RAP1260 - 3
RG-RAP1260 - 4
RG-RAP1260 - 5
RG-RAP1260 - 6
RG-RAP1260 - 7
RG-RAP1260 - 8
RG-RAP1260 - 9
RG-RAP1260 - 10
RG-RAP1260 - 11
RG-RAP1260 - 12
RG-RAP1260 - 13
RG-RAP1260 - 14
RG-RAP1260 - 15
RG-RAP1260 - 16
RG-RAP1260 - 17
RG-RAP1260 - 18
RG-RAP1260 - 19
RG-RAP1260 - 20
RG-RAP1260 - 1
RG-RAP1260 - 2
RG-RAP1260 - 3
RG-RAP1260 - 4
RG-RAP1260 - 5
RG-RAP1260 - 6
RG-RAP1260 - 7
RG-RAP1260 - 8
RG-RAP1260 - 9
RG-RAP1260 - 10
RG-RAP1260 - 11
RG-RAP1260 - 12
RG-RAP1260 - 13
RG-RAP1260 - 14
RG-RAP1260 - 15
RG-RAP1260 - 16
RG-RAP1260 - 17
RG-RAP1260 - 18
RG-RAP1260 - 19
RG-RAP1260 - 20
RG-RAP1260, Reyee Wi-Fi 6 AX3000 Dual-Band Wall Plate Access Point66666
Hotel, Home, Office, etc.
  • Dual-radio performance, gigabit wireless wall-mounted AP
  • Better experience with MU-MIMO under 802.11ax
  • Easy installation, worldwide compatible
  • Capable of Reyee Mesh and 802.11K/V/R
  • Powerful Standalone Portal via Ruijie Cloud
Wi-Fi 6 AX3000 Dual-band Multi-Port Wall AP
RG-RAP1260
  • POE
  • 2.4G/5G Dual-band
  • 3000Mbps
    Internet Rate
  • 110 Recommended
    Concurrent Users
  • POE
  • 2.4G/5G Dual-band
  • 3000Mbps Internet Rate
  • 110 Recommended
    Concurrent Users
More Than Wi-Fi, 4 Ports Meet Multi-Task Scenarios
Latency on Video Conference?
RAP1260 Makes Terminal Access Rate Up To 900Mbps.
Smart AI Roaming Enhances Wireless Experience Anywhere You Go
Reyee free DDNS
Cloud portal authentication
Remote monitoring and maintenance
Key Specifications
4K-QAM
MLO
Maximum number of SSIDs
  • 8
  • 64 (2.4 GHz) 256 (5 GHz) 256 (2.4 GHz and 5 GHz enabled)
Recommended number of associated wireless clients
  • ● Support for IEEE 802.11ax and 160 MHz: 16 (2.4 GHz) 94 (5 GHz) 110 (2.4 GHz and 5 GHz enabled) ● Support for IEEE 802.11ax and 80 MHz: 16 (2.4 GHz) 64 (5 GHz) 80 (2.4 GHz and 5 GHz enabled) ● Support for IEEE 802.11ac: 8 (2.4 GHz) 32 (5 GHz) 40 (2.4 GHz and 5 GHz enabled)
  • Wall AP
6 GHz Wi-Fi
5 GHz Wi-Fi
  • Wi-Fi 4 (IEEE 802.11a/n) Wi-Fi 5 (IEEE 802.11ac) Wi-Fi 6 (IEEE 802.11ax)
2.4 GHz Wi-Fi
  • Wi-Fi 4 (IEEE 802.11b/g/n) Wi-Fi 6 (IEEE 802.11ax)
  • Dual-radio 4 spatial streams ● 2.4 GHz: 2 x 2, MU-MIMO ● 5 GHz: 2 x 2, MU-MIMO
6 GHz channel width
  • 2974 Mbps
  • 2401 Mbps
  • 573 Mbps
Maximum transmit power (6 GHz)
Maximum transmit power (5 GHz)
  • Combined power: 21 dBm (single-stream power: 18 dBm) Note: The transmit power varies according to regulations in different countries and regions.
Maximum transmit power (2.4 GHz)
  • Frequency bands and maximum Effective Isotropic Radiated Power (EIRP): Note: Country specific restrictions apply. European Union & United Kingdom: 2400–2483.5 MHz, EIRP ≤ 20 dBm 5150–5350 MHz, EIRP ≤ 23 dBm 5470–5725 MHz, EIRP ≤ 30 dBm United States: 2400–2483.5 MHz, max output power ≤ 30 dBm & EIRP ≤ 36 dBm 5150–5250 MHz, max output power ≤ 30 dBm & EIRP ≤ 36 dBm 5250–5350 MHz, max output power < 24 dBm & EIRP ≤ 30 dBm 5470–5725 MHz, max output power < 24 dBm & EIRP ≤ 30 dBm 5725–5850 MHz, max output power ≤ 30 dBm & EIRP ≤ 36 dBm Myanmar: 2400–2483.5 MHz, EIRP ≤ 23 dBm 5725–5825 MHz, EIRP ≤ 30 dBm Thailand: 2400–2483.5 MHz, EIRP ≤ 20 dBm 5150–5350 MHz, EIRP ≤ 23 dBm 5470–5725 MHz, EIRP ≤ 30 dBm 5725–5825 MHz, EIRP ≤ 30 dBm Indonesia: 2400–2483.5 MHz, EIRP ≤ 27 dBm 5150–5350 MHz, EIRP ≤ 23 dBm 5725–5825 MHz, EIRP ≤ 23 dBm Egypt: 2400–2483.5 MHz, EIRP ≤ 20 dBm 5150–5350 MHz, EIRP ≤ 23 dBm
Number of 10/100BASE-T ports
PoE In standard
  • ● IEEE 802.3af (PoE) ● IEEE 802.3at (PoE+)
  • 14 W
  • IP41
  • 86 mm x 24 mm x 124 mm (3.39 in. x 0.94 in. x 4.88 in.) (excluding the mounting bracket)
  • N/A
  • ≤ 0.26 kg (0.57 lbs.) (without packaging materials)
