To see the differences, start by clicking "Compare". Your selected products will appear in the
list below,
ready for comparison.
Reyee Product Suggestions
Not sure what to compare? Click “Add Product” and discover similar products recommended for you.
Combine Different Types
group them for
a clear view.
Edit Your List Anytime
products as you
like.
"Compare" box
RG-EST310 V2 has adopted the new high-performance 5GHz single-band dual-stream chip solution, which offers up to 867Mbps wireless transmit rate and significantly enhances the efficiency and stability of network bridge data transmission.
Key Specifications
Single-radio 2 spatial streams ● Radio 1: 5 GHz, 2 spatial streams: 2 x 2, MIMO
5 GHz channel width
Auto/20/40/80 MHz
Number of PoE In ports
Bridge speed test
SON
AI heatmap
No
SNMPv1, v2c, and v3
No
5GHz wireless bridge, including 2 devices for the recorder-end and camera-end, paired by default without requiring any configuration; up to 867Mbpsthroughput,built-in directionalantenna,supportWeb/Real-easyappmanagement;12VDCand24VDC non-standardPoE;Wall-mounted/Pole-mountedinstallation.
contact
online
support.
Don't have an account?
your cookie settings.
you.
Performance cookies
Essential cookies
