RG-NBR6215-E - 1
RG-NBR6215-E - 2
RG-NBR6215-E - 3
RG-NBR6215-E - 4
RG-NBR6215-E - 5
RG-NBR6215-E - 1
RG-NBR6215-E - 2
RG-NBR6215-E - 3
RG-NBR6215-E - 4
RG-NBR6215-E - 5
Compare
RG-NBR6215-E Reyee High-performance Cloud Managed Security Router
Enterprise, Hospitality, Factory, Retail, etc.
  • High performance, “All-in-One” cloud managed security router.
  • Flexible linkage with Ruijie multi-software platform.
  • L7 DPI and intelligent flow control in VPN tunnels.
High Performance,
“All-in-One” Security Router
  • Up to 2.5Gbps
    Throughput
  • Up to 1500
    Concurrent Users
  • 10G SFP+ Port
    Uplink
  • Up to 1000
    IPSec Tunnels
  • Free Cloud
Multi-service, One is Enough
All-in-one: Self-security + Network Behavior Audit = NBR
Flexible linkage with Ruijie Multi-software Platform
L7 DPI and Intelligent Flow Control in VPN Tunnels
Not only powerful behavior management(2500+ rules library) based on L7 DPI,
but also visualized VPN, to guarantee key service in tunnel.
  • Self-organization network
  • Scenario-based configuration guide
  • Marketing portal authentication
  • Quickly advanced service setup by APP
  • Cloud APP maintenance remotely
Package Contents
Router 1 1 1 1
Power Cord 1 1 1 1
Rubber Pads 4 4 4 4
Mounting Brackets 2 2 2 2
M4 x 8 mm Screws 6 6 6 6
DB-9 Console Cable 1 1 1 1
Ethernet Cable 1 1 1 1
User Manual 1 1 1 1
Warranty Card 1 1 1 1
