RG-M32 - 1
RG-M32 - 2
RG-M32 - 3
RG-M32 - 4
RG-M32 - 5
RG-M32 - 6
RG-M32 - 1
RG-M32 - 2
RG-M32 - 3
RG-M32 - 4
RG-M32 - 5
RG-M32 - 6
Compare
RG-M32 3200M Wi-Fi 6 Dual-band Gigabit Mesh Router
Home scenarios (e.g. Villa, Large-sized apartment, Bungalow), SOHO office, small shop, etc
  • Next-gen gigabit Wi-Fi 6 standard
  • 4x4 Enterprise-level chipset, better stability under heavy load
  • 4 Dual-band antennas and 8 signal amplifiers, provide whole-home network coverage
  • Exclusive Reyee Mesh solution, one click to mesh up multiple Reyee Mesh devices
  • Smart signal indicator, find the best spot to place a sub-router
  • Take control of your home network at your fingertips
RG-M32
Mesh More
Cover All
  • 4 Internal
    Dual-band
    Antennas
  • 3200Mbps
  • 802.11ax
Supported by 4x4 Enterprise Level Chipset
Enjoy Better Stability under Heavy Load
Tolly proofs that RG-M32 demonstrates more stable network performance at multiple connections.
Powerful Signal through Multi-walls
Concurrently Support Multiple Devices Connection
  • Signal Visualization
    Smart signal indicator guides you to find the best spot.
  • Mesh by One-click
    You can click the Reyee Mesh button to complete pairing multiple devices with zero configuration.
Seamless Roaming, Full Space Coverage Wi-Fi Solutions
Amazed by Reyee Mesh
Take Control of
Your Home Network
at Fingertips
Set up your home network in Reyee Router App
in two minutes. More Life-time Free functions are
waiting for you to Explore, Experience, Expect.
  • Remote Management
  • Parental Control
  • Smart Home
Key Specifications
  • 4 x internal antennas
Antenna gain (2.4 GHz)
  • 2.5 dBi
Antenna gain (5 GHz)
  • 3 dBi
FEM
  • EPA
Max. Wi-Fi Speed
  • 2.4 GHz, 800 Mbps
    5 GHz, 2402 Mbps
Wi-Fi standard
  • Wi-Fi 6 (IEEE 802.11ax)
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
    128 (5 GHz)
  • 12 (2.4 GHz)
    48 (5 GHz)
Wireless Router 1
Power Adapter 1
Quick Start Guide 1
Cat5E UTP Cable  1
