RG-EW300T - 1
RG-EW300T - 2
RG-EW300T - 3
RG-EW300T - 4
RG-EW300T - 5
RG-EW300T - 6
RG-EW300T - 7
RG-EW300T - 8
RG-EW300T - 1
RG-EW300T - 2
RG-EW300T - 3
RG-EW300T - 4
RG-EW300T - 5
RG-EW300T - 6
RG-EW300T - 7
RG-EW300T - 8
Compare
RG-EW300T N300 Wireless 4G LTE Router
Home scenarios (e.g. Villa, Large-sized apartment, Bungalow), SOHO office, small shop, etc.
  • Cloud-managed
  • Plug and Play
  • 4 External Antennas
  • Max. Speed up to 300 Mbps
  • Three-year Warranty
RG-EW300T,
Always Stay Connected
RG-EW300T,Always Stay Connected
Cloud-managed 300 Mbps Wireless 4G LTE Router
Enjoy the Internet Wherever You Are
Leveraging the cutting-edge LTE technology, the RG-EW300T
delivers cable-free internet connectivity. With a simple SIM card
and data plan, this router seamlessly connects to nearby mobile
signal towers for instant internet access.
EW300T delivers cable-free
simple SIM card and data plan,
to nearby mobile signal towers
No Configuration Needed,
Plug and Play
Once you insert the SIM card and turn on the router, you’re
all set to surf the speedy 4G LTE network.
router, you’re all set to surf the speedy 4G
LTE network.
High-Quality Hardware for
Smooth Experience
  • Seamless Connectivity
  • Highly Adaptable
The router is equipped with 4 external antennas to ensure a
more stable signal and broader coverage. Along with the 4G
LTE modem, it is compatible with most service providers.
3 × 10/100Mbps LAN Ports and 1 × 10/100Mbps LAN/WAN Port
meet your wired terminal access needs. The fully functional
LAN/WAN port allows you to use the RG-EW300T as a regular
router, which is compatible with cable, fiber, and DSL modems.
  • High-Quality Hardware for
    Smooth Experience
    The router is equipped with 4 external antennas to ensure a more stable signal and broader coverage. Along with the 4G LTE modem, it is compatible with most service providers.
    Smooth Experience
    3 × 10/100Mbps LAN Ports and 1 × 10/100Mbps LAN/WAN Port meet your wired terminal access needs. The fully functional LAN/WAN port allows you to use the RG-EW300T as a regular router, which is compatible with cable, fiber, and DSL modems. 3 × 10/100Mbps LAN Ports and
Experience Internet Freedom
The Ruijie Reyee APP provides incredible advanced features, allowing you to remotely manage your network at any time.
  • Network Status Monitoring
    Monitor your router's status in real-time, keeping you updated on connection status bandwidth usage, and network issues.
  • Online Device Monitoring
    Monitor the online status of devices connected to your router with ease.
  • Remote Reboot
    Experiencing network issues? Try remote rebooting for a quick fix.
  • Password Changing
    Worried about Wi-Fi security? Protect your network with the password management feature.
RG-EW300T, Stay Connected Everywhere
Everywhere
The 4G LTE router RG-EW300T offers convenient, reliable, and seamless networking, catering to diverse scenarios.
  • House Without Wired Connection
  • Remote Area
  • Travel and Outdoors
  • Mobile Office
Key Specifications
  • 4 x external antennas
Antenna gain (2.4 GHz)
  • 4 dBi
Antenna gain (5 GHz)
  • 4G-LTE: 3 dBi
FEM
  • iPA
Max. Wi-Fi Speed
  • 2.4 GHz, 300 Mbps
    LTE-FDD: TX 150Mbps RX50Mbps
    LTE-TDD: TX130Mbps RX 30Mbps
Wi-Fi standard
  • Wi-Fi 4 (IEEE 802.11 n)
    4G-LTE:
    WCDMA: B1/B5/B8
    LTE-FDD:B1/B3/B5/B7/B8/B20/B28
    LTE-TDD: B38/B40/B41
Ruijie Cloud management
Reyee Mesh 3.0
Reyee Mesh 3.0
  • 16(2.4 GHz)
  • 8 (2.4 GHz)
