RG-WALL 1600-Z3200-S - 1
RG-WALL 1600-Z3200-S - 2
RG-WALL 1600-Z3200-S - 3
RG-WALL 1600-Z3200-S - 4
RG-WALL 1600-Z3200-S - 5
RG-WALL 1600-Z3200-S - 6
RG-WALL 1600-Z3200-S - 7
RG-WALL 1600-Z3200-S - 8
RG-WALL 1600-Z3200-S - 9
RG-WALL 1600-Z3200-S - 10
RG-WALL 1600-Z3200-S - 11
Functions
Basic Functions
Deployment scenarios
Routing mode
Transparent mode
Off-path mode
Quick onboarding wizard
Port scan
Traffic learning
Diagnostic center
Security Functions
Policy simulation
Redundant policy optimization
Expired policy optimization
Policy lifecycle management
DDoS attack defense
ARP attack defense
Virus protection templates
Threat intelligence
Management Functions
Visualized service security
Policy delivery on the cloud
Hot patches
SNMP
10G SFP+ Port
Cost-effective
Coping with heavy traffic
Ruijie Cloud Management
Scalable Performance
Flexible expansion by license
Port Scan + Traffic Learning,
knowledge.
1. Port Scan
2. Traffic Learning
3. Policy Generation
Intelligent Diagnostic Center
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
Product Performance
Firewall Throughput4
Firewall (Traffic Mix)
IPS1
NGFW1,2
Threat Protection1,3
10 Gbps
1 Gbps
900 Mbps
850 Mbps
800 Mbps
10 Gbps
2 Gbps
1.6 Gbps
1.2 Gbps
900 Mbps
10 Gbps
3 Gbps
2 Gbps
1.6 Gbps
1 Gbps
2G: RG-WALL 1600-Z3200-S chassis + one RG-WALL 1600-Z3200-S-1G-LIC performance license
3G: RG-WALL 1600-Z3200-S chassis + two RG-WALL 1600-Z3200-S-1G-LIC performance licenses
10 Gbps
1.8 Mpps
Concurrent sessions (TCP)
500000
New sessions/second (TCP)
50000
Firewall policies
3000
SSL VPN throughput
384 Mbps
500
3 Gbps
1.3Gbps
Gateway-to-Gateway IPsec VPN tunnels
1000
Product weight
2.9 kg
4.0 kg
1 U rack
Fixed 1G electrical port
8 × 10/100/1000 Base-T RJ-45 Ethernet electrical ports with auto-negotiation
Fixed 1G optical port
1 × 1000BASE-SX/LX/ZX Ethernet optical port
Fixed 10G optical port
1 × 10GBASE-SR/LR/ZR Ethernet optical port (with 10G/1G auto-negotiation)
1 × 10/100/1000 Base-T RJ-45 Ethernet port with auto-negotiation (reusing port Ge 0/0)
Console port
1 x RJ-45 console port (serial console port)
2 x USB 2.0 ports
Storage Specifications
Storage
Hard disk
Built-in single power module:
l Rated input current: 0.65 A
Max. Power Consumption
< 25 W
0°C to 45°C (32°F to 113°F)
Noise level
43.7 dB
Operating altitude
0–5000 m (0–16404 ft.)
Compliance
EMC SZEM2302000974ATV
LVD SZES2302001034AT
Network
Network
Physical interface
Configuring routing or transparent mode for interfaces
Sub-interface
Bridge interface
Static route
PBR
Routing table
Address management list
Assigned DHCP address list
DNS server
Object
Object
Address/Address group
Zone
Configuring security zones
Service/Service group
Time plan
Configuring virus protection templates Configuring quick scan or deep scan; configuring templates based on protocols and directions; setting excluded viruses
Intrusion prevention template
Configuring intrusion prevention templates Configuring rule filters based on objects, severity, protocols, threat types; setting excluded rules
SSL proxy certificate
Adding, importing, deleting, viewing, and downloading SSL proxy certificates Configuring a global SSL proxy certificate
Server certificate
Security rule base
Policy
Policy
Traffic learning
NAT
NAT and NAT policies
Policy import
Batch import of NAT policies
ALG
Server mapping
Address pool
Security policy
Security policy
Simulation policy
Policy configuration wizard
Policy optimization
Policy lifecycle
Port scan
DoS/DDoS attack defense
ARP attack defense
Local defense
Blocklist/Allowlist
SSL proxy policy
SSL proxy template
Allowlist
System
System
Administrator
Administrator role
Clock configuration
Service parameter
Authorization management
Device information
System restart
System upgrade
Upgrading the system
Patch installation
Configuration backup
Import and export of device configurations
Factory settings restoration
Signature library upgrade
Cloud management platform
Device binding
Ping
Ping for troubleshooting
Tracert
Tracert for troubleshooting
Packet obtaining tool
One-click collection
Device health
Device health diagnosis
Service diagnosis
Service continuity diagnosis
Breakdown record
Breakdown information records
Device log retention
External APIs
RESTful APIs for third-party interconnection
Product Model Product Description
RG-WALL 1600-Z3200-S The RG-WALL 1600-Z3200-S cloud management firewall provides 8 x 1G Ethernet ports,
1 x 1G SFP port, 1 x 10G SFP+ port, and single power supply (for factory delivery). The firewall is 1 U high and supports expansion of 1 TB enterprise-class hard disk.
RG-WALL 1600-Z3200-S-1G-LIC Performance expansion license for the RG-WALL 1600-Z3200-S cloud management firewall:
One license provides 1G expansion for network throughput.
RG-WALL 1600-Z3200-S-LIS-M-1Y Intrusion prevention (IPS), antivirus (AV), app identification (APP),
URL signature library four-in-one license for the RG-WALL 1600-Z3200-S cloud management firewall:
One license provides one-year upgrade services for IPS, AV, APP, and URL signature libraries.
RG-WALL 1600-Z3200-S-LIS-E-1Y Intrusion prevention (IPS), antivirus (AV), app identification (APP), threat intelligence,
URL signature library five-in-one license for the RG-WALL 1600-Z3200-S cloud management firewall:
One license provides one-year upgrade services for IPS, AV, APP, and URL signature libraries and one-year threat intelligence services.
RG-NSEC-HDD-1T 1 TB enterprise-class hard disk can be added to meet hard disk configuration requirements.
