RG-NIS2100-8GT2SFP-HP - 1
RG-NIS2100-8GT2SFP-HP - 2
RG-NIS2100-8GT2SFP-HP - 3
RG-NIS2100-8GT2SFP-HP - 4
RG-NIS2100-8GT2SFP-HP - 5
RG-NIS2100-8GT2SFP-HP - 6
RG-NIS2100-8GT2SFP-HP, switch industrial gerenciado na nuvem de 10 portas, com 1 porta PoE++, 7 portas PoE+ e 2 portas de uplink SFP
CFTV, fábricas, áreas litorâneas, ambientes com muita poeira, etc.
  • Recursos de nível industrial garantem uma operação estável entre -40 ℃ e +75 ℃
  • Proteção IP40 contra partículas sólidas de 1 mm
  • Proteção contra surtos de 6 kV e picos de tensão
  • Saída PoE de 90 W: solução perfeita para dispositivos de alta potência
  • Configuração do ERPS imediata e rápido failover de serviço garantem estabilidade da rede
  • Ruijie Cloud: Gerenciamento remoto fácil, a qualquer hora e em qualquer lugar
10-Port Cloud Managed Industrial Switch
  • 1 x PoE++ Port
  • 7 x PoE+ Ports
  • 2 x SFP Uplink Ports
  • 5 Years Warranty
Industrial-Grade Features for
Handling Harsh Environmental Challenges
Wide Temperature Range
Full Aluminum Casing Ensures a Wide Operating Temperature Range of -40°C to +75°C
Robust Shield Ensures Network Stability
  • 6kV Surge Protection
    Against Voltage Spikes
  • EMC Level 4
    Against Electromagnetic Interference
90W
PoE Output
90W PoE Output
Perfect for
High-Power Device
Small in Size, Ultimate in Convenience
Convenience
    • Compact design,
      perfectly fit into a waterproof outdoor box
    • DIN rail mounting
      support for simplified installation
Compact design, perfectly fit into a waterproof outdoor box
DIN rail mounting support for simplified installation
DIP Switch for Instant ERPS Configuration
Rapid Service Failover Ensures Network Stability
LAN
Self-Organizing
Network
Simplify Setup by
Easy Remote Management Anytime, Anywhere
Principais especificações
  • 5 years
  • 8
  • 8
  • 8
  • 8
  • Default: 228 W
    MAX: 300 W
  • Port 1: 1–2 (+), 3–6 (-), 4–5 (+), 7–8 (-)
    Ports 2–8: 1–2 (+), 3–6 (-)
  • 14.8 Mpps
  • 20 Gbps(bit/s)
Informações do pedido
Device RG-NIS2100-8GT2SFP-HP
Installation Guide 1
Warranty Card 1
Shipping Weight 1.10 kg (2.43 lbs)
