首頁
部落格
Product Insider
Outdoor CPE Solutions for System Integrators AirMetro Guide
Ruijie Reyee
Ruijie Reyee
2026年9月23日
標籤:
Why Outdoor CPE Selection Matters for System Integrators
System integrators deploying outdoor wireless networks face a recurring set of challenges: connecting CCTV cameras across large properties, extending internet access to rural or remote sites, and linking buildings without the cost and time burden of trenching fiber. For these professionals, the choice of an outdoor Customer Premises Equipment (CPE) platform directly affects installation speed, project margins, and long-term network reliability. Ruijie Reyee, the brand under Ruijie Networks, offers the AirMetro Series wireless bridge and outdoor CPE line specifically engineered to address these integrator-facing pain points.
Understanding the Core Pain Points in Outdoor Wireless Deployment
Before evaluating any outdoor CPE product, integrators typically define their requirements around four core needs:
  • A fiber alternative that avoids the permitting delays and excavation costs associated with underground cabling
  • Long-distance connectivity capable of bridging signals across parking lots, construction sites, farms, or building-to-building gaps
  • Fast deployment that minimizes technician labor hours per site
  • Lower installation cost to protect project profitability, especially across multi-site rollouts
These requirements are common across the target customer base for outdoor wireless bridges, which includes CCTV installers, construction site operators, farm owners, remote building managers, and wireless ISPs. Each of these customer types shares a similar constraint: they need dependable connectivity in locations where traditional wired infrastructure is impractical or too expensive to install.
AirMetro Wireless Technology: Built for PTP and PTMP Scenarios
The AirMetro Series is designed around two primary transmission modes: Point-to-Point (PTP) and Point-to-Multipoint (PTMP). PTP connections are typically used for direct building-to-building links, such as connecting an office building to a warehouse or a construction trailer to a main site. PTMP configurations, on the other hand, allow a single base station to distribute connectivity to multiple remote points simultaneously.
A defining technical capability of the AirMetro platform is that one base station supports up to 32 CPE connections in a PTMP configuration. This is particularly relevant for wireless ISPs and integrators managing distributed CCTV networks, where a single elevated base station can serve numerous camera locations or remote client sites without requiring a separate wired connection for each.
30-Second Pairing: Reducing Labor Time on Site
One of the most direct ways the AirMetro Series addresses integrator profitability is through its 30-second pairing feature. Traditional outdoor wireless bridge installations often require manual alignment, configuration, and testing that can consume significant technician time, particularly across multiple remote sites. The 30-second pairing capability is built to:
  • Accelerate on-site installation
  • Reduce labor cost per deployment
  • Simplify the overall setup process for field technicians
For system integrators managing multiple simultaneous installations, this kind of deployment efficiency has a direct impact on how many sites a crew can complete in a given timeframe.
Typical Application Scenarios for Outdoor CPE
The AirMetro Series is positioned around three primary use cases that reflect common integrator project types.
CCTV wireless backhaul is one of the most frequent applications, covering parking lots, construction sites, and large outdoor areas where running fiber to every camera location is neither practical nor cost-effective. By using wireless backhaul instead, integrators can avoid fiber installation entirely while still achieving long-distance camera connections.
Rural internet connectivity represents a second major scenario, extending broadband access to farms and remote buildings where wired infrastructure does not reach. This application allows integrators to offer an affordable broadband extension solution to customers in underserved locations.
Building-to-building connection is the third core scenario, commonly applied to office buildings and warehouses that need to share network resources without a physical cable run between structures.
Integration with the Broader Reyee Cloud Ecosystem
For system integrators, deploying a single device type in isolation is rarely the full picture. Most projects involve a mix of switches, access points, PoE devices, and outdoor bridges working together across a site. This is where the positioning of Ruijie Reyee as a full-portfolio provider becomes relevant to integrators evaluating outdoor CPE options.
The Reyee Cloud Platform provides unified management not only for outdoor wireless devices like the AirMetro Series, but also for Cloud Managed Switches, PoE Switches, WiFi 6/WiFi 7 Access Points, Industrial Switches, and Business Routers. For an integrator working on a CCTV backhaul project, for example, this means the same cloud dashboard used to monitor the outdoor bridge can also oversee the PoE switches powering the cameras and the routers handling internet gateway functions on site.
A notable aspect of this platform is its lifetime free core cloud management, which stands in contrast to subscription-based cloud platforms common in the networking industry. For integrators pricing out multi-year service agreements for clients, the absence of a mandatory subscription fee can be a meaningful factor in total cost of ownership calculations presented to end customers.
Why Full Portfolio Coverage Matters to Integrators
System integrators frequently serve customers whose needs span more than just outdoor connectivity. A CCTV installer deploying an AirMetro wireless backhaul link for a warehouse, for instance, may also need PoE switches to power the cameras themselves, or a business router to manage secure internet access for the site. Because Ruijie Reyee's complete SMB networking ecosystem includes Cloud Managed Switches, PoE Switches, WiFi 6/WiFi 7 Access Points, Industrial Switches, Wireless Bridges, and Business Routers, integrators have the option to source multiple layers of a project's network infrastructure from a single ecosystem managed through one cloud platform.
This portfolio approach is particularly relevant across the target industries listed for the broader Reyee ecosystem, including hotels, schools, retail chains, factories, warehouses, construction sites, and energy systems—many of which overlap directly with the customer base for outdoor CPE deployments, such as construction sites and remote buildings.
Key Considerations for System Integrators Evaluating Outdoor CPE
When assessing outdoor CPE options, integrators should weigh the following factors based on their specific project requirements:
  • Deployment mode needed: Whether the project calls for a direct PTP link or a PTMP setup serving multiple remote points
  • Scale of connections: Whether up to 32 CPE connections from a single base station meets the project's distribution needs
  • Installation timeline: Whether rapid pairing capabilities align with labor budget constraints
  • Ecosystem compatibility: Whether the outdoor CPE needs to integrate with other networking equipment already planned for the site, such as PoE switches or business routers
  • Long-term management cost: Whether ongoing cloud subscription fees are a factor in the total project quote
Conclusion
For system integrators managing outdoor connectivity projects—whether for CCTV backhaul, rural broadband extension, or building-to-building links—the combination of PTP/PTMP flexibility, 30-second pairing, support for up to 32 CPE connections per base station, and integration with the Reyee Cloud Platform's lifetime free core cloud management positions the AirMetro Series as a practical option worth evaluating. Ruijie Reyee's broader networking portfolio, spanning switches, PoE switches, wireless access points, industrial switches, and business routers, further allows integrators to consolidate multiple aspects of a project under a single cloud-managed ecosystem, an approach that can simplify both deployment and long-term maintenance across distributed sites.
標籤:
相關部落格
聯絡我們
聯絡我們
我們能如何協助您?
聯絡我們
取得訂單協助
聯絡我們
取得技術支援
