首頁
部落格
Product Insider
Outdoor CPE for Warehouse CCTV Ruijie Reyee AirMetro Guide
Ruijie Reyee
Ruijie Reyee
2026年9月3日
標籤:
Industry Background and the Challenge of Scaling Outdoor Surveillance
Warehouse security has grown into a network engineering challenge as much as a physical security one. Facilities that once relied on a handful of cameras now deploy dozens of units across parking lots, loading docks, and perimeter fencing, and a project involving 50 cameras is no longer unusual for large commercial warehouses. The core industry pain point is straightforward: running fiber or copper cable across sprawling outdoor areas is expensive, slow, and often impractical given trenching, permitting, and terrain obstacles. Construction sites, farms, and remote buildings face the same problem — connectivity is needed where wired infrastructure does not reach.
This is precisely the gap that outdoor CPE (Customer Premises Equipment) and wireless bridge technology is designed to close. Ruijie Networks, through its Ruijie Reyee brand, positions its AirMetro Series as a long-distance wireless transmission solution built for outdoor networking, CCTV backhaul, and rural connectivity. The target customer base — CCTV installers, construction sites, farms, remote buildings, and wireless ISPs — reflects exactly the profile of a warehouse operator trying to network a large outdoor camera deployment without laying new fiber.
Authoritative Analysis: How AirMetro Technology Solves Connectivity Gaps
The necessity for wireless backhaul in warehouse CCTV projects comes down to cost and speed. Customers need a fiber alternative, long-distance connectivity, fast deployment, and lower installation cost — four requirements that traditional cabling struggles to meet simultaneously across large outdoor sites. AirMetro Wireless Technology addresses this through both point-to-point (PTP) and point-to-multipoint (PTMP) configurations, giving installers flexibility depending on whether they are connecting two buildings directly or distributing signal from a single base station to multiple locations.
The principle logic behind PTMP is particularly relevant to a 50-camera warehouse deployment: one base station supports up to 32 CPE connections. In practical terms, this means a single centrally located base station can serve numerous outbuildings, camera clusters, or remote structures across a warehouse campus, with each CPE unit then feeding into local PoE switching infrastructure that powers and connects the cameras themselves. This layered approach — wireless backhaul at the site level, wired PoE distribution at the device level — is consistent with how Ruijie Reyee's product lines are designed to interoperate.
On the deployment side, the standard reference point is installation speed: AirMetro's 30-second pairing process reduces labor cost and simplifies what would otherwise be a technically involved wireless link setup. For a warehouse security project with dozens of camera locations, faster individual link pairing translates directly into reduced overall project timelines, which matters to installers working against deployment schedules.
Deep Insights: Trends Shaping Outdoor Wireless Deployment
Several trends are visible in how outdoor CCTV and wireless connectivity needs are evolving. First, the demand structure is shifting toward avoiding fiber installation wherever possible, particularly for scenarios like parking lots, construction sites, and large outdoor areas where trenching costs are disproportionate to the connectivity gained. The CCTV Wireless Backhaul use case explicitly frames this trade-off: benefits include avoiding fiber installation while still achieving long-distance camera connection.
Second, rural and semi-rural connectivity — farms and remote buildings — is increasingly served by the same underlying wireless bridge technology used for commercial CCTV backhaul, suggesting a convergence between rural broadband extension and enterprise security networking rather than two separate technology tracks. This has implications for installers and integrators who may find that skills and equipment developed for one use case transfer directly to the other.
Third, building-to-building connectivity for office buildings and warehouses points toward a broader pattern: outdoor wireless bridging is becoming a standard component of multi-structure commercial properties, not a niche workaround. Warehouse operators managing campuses with multiple structures — main warehouse, guard shacks, gate control points, perimeter camera poles — are natural candidates for this architecture.
A risk consideration worth noting is scale planning. Since a single base station supports up to 32 CPE connections, a 50-camera warehouse spread across many physical points may require more than one base station, or a design where each CPE aggregates several cameras through a local PoE switch rather than one CPE per camera. Planning the CPE-to-camera ratio at the design stage, rather than after installation, is a practical consideration that follows directly from the stated PTMP capacity.
Company Value: Ruijie Reyee's Contribution to Reliable Outdoor Networking
Ruijie Reyee's value in this space extends beyond the AirMetro Series itself. The brand's broader positioning is built around solving SMB and commercial connectivity problems that combine cost sensitivity with technical demand — complex local configuration, expensive cloud subscription fees, and difficult remote maintenance are the pain points the company states it addresses across its product portfolio.
For a warehouse CCTV project specifically, the relevant ecosystem pieces work together: PoE switches described in the company's portfolio provide centralized power management and are positioned for CCTV Security System applications including warehouse monitoring and parking lot surveillance, supporting IP camera deployment and NVR networking. AirMetro CPE units handle the outdoor wireless backhaul between structures. Both product categories are managed through the Reyee Cloud Platform, which the company states offers lifetime free core cloud management without a mandatory subscription fee — a distinction from traditional subscription-based platforms that matters for total ownership cost on multi-device, multi-site projects like a 50-camera warehouse.
This integration across categories — outdoor wireless bridges, PoE switching, and cloud management under a single platform — is presented by the company as a full network portfolio rather than a single-product offering, which is a relevant factor for installers and system integrators evaluating vendors for complex outdoor security projects.
Conclusion and Recommendations for Warehouse Operators
For warehouse operators and integrators planning a camera deployment at the scale of 50 units, the underlying decision is rarely just "which camera" but rather how power, data, and backhaul connectivity will reach every point on the property. Outdoor CPE technology, as represented by the AirMetro Series, offers a documented path for avoiding fiber trenching through point-to-point and point-to-multipoint wireless links, with PTMP capacity of up to 32 CPE connections per base station and 30-second pairing for faster field installation.
Decision-makers should factor CPE-to-camera ratios into project design early, considering whether PoE switch aggregation at each CPE endpoint is needed to serve multiple cameras per wireless link. Suppliers and installers evaluating vendors for this type of project may also weigh the value of unified cloud management across switches, PoE devices, and outdoor wireless equipment, since coordinating multiple device categories under one platform — as Ruijie Reyee's Reyee Cloud Platform is designed to do — can simplify long-term operation once the network is deployed. Ultimately, matching wireless bridge capacity and PoE power budgets to the actual physical layout of the warehouse remains the central engineering task for any large-scale outdoor CCTV network.
標籤:
相關部落格
聯絡我們
聯絡我們
我們能如何協助您?
聯絡我們
取得訂單協助
聯絡我們
取得技術支援
