Construction sites present a unique networking challenge: cameras, sensors, and monitoring equipment must be deployed across wide, often unfinished outdoor areas where running fiber or cable is impractical, expensive, and time-consuming. For contractors, CCTV installers, and site managers searching for a reliable, budget-friendly way to connect surveillance equipment without digging trenches or laying cable, Ruijie Reyee's AirMetro Series wireless bridges and outdoor CPE devices offer a purpose-built answer grounded in real-world industrial networking needs.
The AirMetro Series is designed as a long-distance wireless transmission solution for outdoor networking, CCTV backhaul, and rural connectivity. Rather than requiring physical cabling between a camera location and the network core, this wireless bridge technology creates a point-to-point (PTP) or point-to-multipoint (PTMP) wireless link that carries data across open, unstructured terrain — exactly the kind of environment found on active construction sites.
The AirMetro Series is built with several practical deployment scenarios in mind, including:
For construction site operators specifically, this means camera systems, temporary offices, and monitoring stations can all be networked without waiting for permanent utility work.
Construction and outdoor surveillance projects commonly run into the same set of obstacles:
The AirMetro Series is built specifically to answer these pressures, giving installers a way to extend network connectivity without the capital expense and lead time associated with fiber runs.
At the core of the product line is AirMetro Wireless Technology, engineered to support both point-to-point (PTP) links — ideal for connecting two fixed locations such as a security office and a remote camera pole — and point-to-multipoint (PTMP) configurations, which allow a single base station to serve numerous outdoor endpoints across a sprawling site.
One of the most practical advantages for time-sensitive construction environments is the device's 30-second pairing capability. This feature translates directly into:
For a construction site where cameras may need to be repositioned as work progresses, this rapid pairing process significantly reduces the friction of moving or adding wireless links.
The AirMetro platform's PTMP capability allows a single base station to support up to 32 CPE connections. This is particularly relevant for large construction sites or multi-building projects where dozens of cameras or sensors need to be connected back to a central point without running individual cable paths to each unit.
The most directly relevant use case for construction environments is CCTV wireless backhaul. Typical scenarios include:
The benefits are straightforward: operators can avoid fiber installation entirely while still achieving long-distance camera connection, keeping surveillance coverage continuous even as the site evolves.
Beyond construction, the same wireless bridge technology supports rural internet connectivity for farms and remote buildings, providing an affordable broadband extension where wired infrastructure doesn't reach.
The AirMetro Series is also applied in building-to-building connection scenarios, linking office buildings and warehouses without the need for new physical cabling between structures — a model directly transferable to multi-structure construction projects.
The AirMetro wireless bridge does not operate in isolation. It is part of the unified Reyee Cloud Platform, which provides centralized management across switches, PoE switches, WiFi APs, routers, and outdoor wireless devices. For construction site operators managing camera networks alongside other on-site connectivity — such as PoE switches powering IP cameras or business routers securing internet access — this means every device can be monitored and configured from a single management layer.
A core advantage of this ecosystem is lifetime free core cloud management. Compared with traditional subscription-based platforms, Ruijie Reyee's approach means no mandatory subscription fee is required to keep devices under centralized cloud oversight, which directly supports a lower total ownership cost — a meaningful consideration for construction firms managing temporary or project-based deployments where ongoing software fees are difficult to justify.
For teams evaluating a wireless bridge supplier for construction site cameras, the practical considerations are consistent: installation speed, distance coverage, cost of ownership, and the number of devices that can be connected to a single base unit. Ruijie Reyee's AirMetro Series addresses each of these directly — a 30-second pairing process for quick setup, PTMP support for up to 32 CPE connections to scale across a large site, and integration into the broader Reyee Cloud Platform for centralized, subscription-free management.
As a brand under Ruijie Networks, Ruijie Reyee is positioned around simplified networking solutions for SMB customers, cloud-managed infrastructure, and cost-effective enterprise-grade products designed for easy deployment by system integrators, installers, and MSPs. For construction site operators and CCTV installers seeking an affordable, fast-to-deploy wireless bridge that avoids the cost and delay of fiber installation, the AirMetro Series offers a technically grounded, purpose-built solution rather than a generic wireless workaround.
聯絡我們
我們能如何協助您?
