RG-AirMetro460F - 1
RG-AirMetro460F - 2
RG-AirMetro460F - 3
RG-AirMetro460F - 4
RG-AirMetro460F - 1
RG-AirMetro460F - 2
RG-AirMetro460F - 3
RG-AirMetro460F - 4
So sánh
RG-AirMetro460F, CPE của Dòng Cầu nối Vô tuyến RG-AirMetro
WISP, CCTV, Thị trấn, Đường phố, Nhà máy, v.v.
  • PTP Khoảng cách Làm việc Tối đa 15 km
  • PTMP Dễ dàng Ghép nối Tất cả trong 30 giây
  • PoE Thụ động 24 V
  • Bảo vệ Chống sét Lan truyền IP65, 6 kV và ESD ±24 kV trong Môi trường Khắc nghiệt
  • 220,32 km/h (137 dặm/giờ) Khả năng sống sót của gió
  • Quản lý Cloud Tất cả trong Một Đơn giản hóa Hành trình Người dùng
RG-AirMetro Series
Wireless Bridges
After pairing, the bridges support:
  • 15km
    Up to 15 km
    Wireless Transmission
  • 32PTMP
    Up to 32 PTMP
    Links
  • Easy Site Survey
    Tool
  • All-in-One Cloud
CPE
Mix freely for Various Scenarios
  • RG-AirMetro460F
    1 x 10/100 Mbps Port
  • RG-AirMetro460G
    1 x 10/100/1000 Mbps Port
Signal
Enhancement
The Secret of Circular Grace
AI Heatmap for Bridge
Working Modes
Supports both PTP
and PTMP
All in
One
Cloud
Guide Your Worry-Free Journey
Principal
Scenarios
Ideal Choice for both WISP and CCTV Scenarios
CPE
RG-AirMetro460G
15 km, 23 dBi
5 GHz, 867 Mbps
RG-AirMetro460F
15 km, 23 dBi
5 GHz, 867 Mbps
Signal Enhancement
Compared with Square Antenna:
The total gain of the circular is increased;
The gain in both horizontal and vertical directions is more balanced;
Therefore, under the same coverage area, the signal of the circular antenna is stronger.
*All data here are theoretical values obtained by Ruijie Reyee internal laboratories through tests carried out under particular conditions. Actual data may vary owing to differences in individual products, software versions, application conditions, and environmental factors. All data is subject to actual usage.
Still Stable
Fearless of Harsh Environment
  • IP65 Weatherproof
  • 220.32 km/h
    (137 mph)
    Wind Survivability
  • 6kV Surge Protection
  • 24kV
    Contact/Air
  • PTMP
    Up to 32 PTMP Links
  • PTP
    Up to 15 km Distance
WISP
Extensive Coverage Without Fiber Connections
CCTV
Affordable Excellence and Smooth Surveillance
Your Real Outdoor Adventure Companion
Alignment Tool
Your Big-Voice, Time-Saver Guide
Spectrum Scan and Link Optimization
Thumbs-Up Guide
  • One-Click Channel Interference Scanning for All Points
  • Automatic Optimization Recommendations
  • Save Time and Effort
Available on both Ruijie Cloud and Ruijie Reyee App
All-in-one Cloud
Quick SetupMonitoring based on Real, Complete TopologyIdentifying Issues by Auto-Alarm
Thông số chính
    3 spatial streams
2.4 GHz channel width
  • Auto/20/40 MHz
5 GHz channel width
  • Auto/20/40/80 MHz
Number of PoE In ports
Bridge speed test
SON
AI heatmap
SNMPv1, v2c, and v3
Tài nguyên All Resources
