RG-ES05G
Fine Craftsmanship Exquisite and Powerful Design
Real 8-Pin Enterprise-grade Quality
Stringent Testing Worry-free
Plug and Play Energy Saving
Strong Adaptability Applicable for Various Scenarios
Matte-finish Diamond Pattern Design
Honeycomb Heat Dissipation Holes
Embedded Foot Pads
Hidden hanging Holes
Plug and Play & Energy Saving
Energy Saving
Auto Power Reduction
Fansless
Noiseless
