Product Description
RG-EW3200GX PRO 3200M Wi-Fi 6 Dual-band Gigabit Mesh Router
Home Scenarios (Including Villa, Large-sized Apartment, Bungalow), SOHO Office, Small Shop, etc.
  • Next-generation gigabit Wi-Fi 6 standard
  • Ultra-high-speed
  • Strong signals received
  • Exclusive Reyee mesh providing full-space-coverage Wi-Fi solution
  • Better stability under heavy load
  • Control of your home network at your fingertips
Time for ,
Time for RG-EW3200GX PRO
RG-EW3200GX PRO, the Red Dot Design Award 2021 winner.
All-round upgrade of Wi-Fi performance, supported by Tolly certificate. Get your home ready for the Next-Gen Gigabit Wi-Fi 6!
5 Gigabit
Ethernet ports
3200M
Dual-band
Supported by 4x4 Enterprise Level Chipset
Enjoy Better Stability under Heavy Load
Tolly proofs that EW3200GX PRO demonstrates more stable network performance at multiple connections.
Ruijie Reyee EW3200GX PRO
Other brand
Concurrently Support Multiple Devices Connection
MU-MIMO together with OFDMA technology significantly improve network performance for multiple terminals
Strong Signal Received, Feels like
“wall-less”
8 omnidirectional antennas + 8 built-in FEM
Guarantee you 150Mbps even through two walls*
Rocket Speed, Can't Wait
Equipped with Wi-Fi 6 technology like OFDMA, 1024 QAM, and the latest 802.11ax standard, 3200GX PRO reaches ultra fast speed, 3200Mbps, enhancing the overall networking experience for users.
Wireless Rate under Real Test
2.4GHz
EW3200GX PRO
90% higher
Other brand 3000M product
5GHz
EW3200GX PRO
34% higher
Seamless Roaming, Full Space Coverage Wi-Fi Solutions
Amazed by Reyee Mesh
Take Control of
Your Home Network
at Fingertips
Set up your home network in Reyee Router App in two minutes. More Life-time Free functions are waiting for you to Explore, Experience, Expect.
Remote Management
Parental Control
Smart Home
Comparison
FAQ
Documents
