To see the differences, start by clicking "Compare". Your selected products will appear in the
list below,
ready for comparison.
Reyee Product Suggestions
Not sure what to compare? Click “Add Product” and discover similar products recommended for you.
Combine Different Types
group them for
a clear view.
Edit Your List Anytime
products as you
like.
"Compare" box
Łatwe zdalne zarządzanie urządzeniami w dowolnym miejscu i czasie.
Zasilanie
12V
Wejście prądu stałego
24V
48V
Kombinezon
Moc Konsumpcja
Moc
Podaż
RG-NIS3100-8GT4SFP-HP
60W
Budżet mocy PoE
120W
Budżet mocy PoE
240W
Budżet mocy PoE
260W
RG-NIS-PA240-54
RG-NIS3100-8GT2SFP-HP
60W
Budżet mocy PoE
120W
Budżet mocy PoE
240W
Budżet mocy PoE
260W
RG-NIS-PA240-54
RG-NIS3100-4GT2SFP-HP
60W
Budżet mocy PoE
120W
Budżet mocy PoE
240W
Budżet mocy PoE
132W
RG-NIS-PA120-54
12V
60W
Budżet mocy PoE
60W
Budżet mocy PoE
60W
Budżet mocy PoE
24V
120W
Budżet mocy PoE
120W
Budżet mocy PoE
120W
Budżet mocy PoE
48V
240W
Budżet mocy PoE
240W
Budżet mocy PoE
240W
Budżet mocy PoE
Kombinezon
Moc Konsumpcja
260W
260W
132W
Moc
Podaż
RG-NIS-PA240-54
RG-NIS-PA240-54
RG-NIS-PA120-54
New power supply models are now available for an enhanced product experience. For End-of-Sale power supply service plan, click here: RG-NIS-PA120-54RG-NIS-PA240-54
Parametry Kluczowe
Layer 2
5 years
Number of 1GE combo ports
No
Number of 10GE SFP+ ports
No
Number of 10/100BASE-T ports
No
No
No
No
240 W
1–2 (+), 3–6 (-)
14.88 Mpps
20 Gbps(bit/s)
400,000 hours
-40ºC to +65ºC (-40°F to 149°F) (installed in a sealed cabinet)
-40ºC to +75ºC (-40°F to 167°F) (installed in a fume hood with a ventilation speed of at least 200LFM (Line Feet Minute)) -40ºC to +80ºC (-40°F to 176°F) (installed in a fume hood with a ventilation speed of at least 400LFM (Line Feet Minute))
Operating altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.) Storage altitude: –500 m to +5,000 m (–1,640.42 ft. to +16,404.20 ft.)
Service port: ±6 kV for common mode Power connector: ±4 kV for common mode and ±2 kV for differential mode
Interface
Jumbo frame length (MTU)
9216 bytes (global configuration mode)
Broadcast storm control
Informacje o zamawianiu
Device
A power adapter is not included with this product and needs to be purchased separately.
you.
Performance cookies
Essential cookies
