RG-RAP73HD - 1
RG-RAP73HD - 2
RG-RAP73HD - 3
RG-RAP73HD - 4
RG-RAP73HD - 5
RG-RAP73HD - 6
RG-RAP73HD - 1
RG-RAP73HD - 2
RG-RAP73HD - 3
RG-RAP73HD - 4
RG-RAP73HD - 5
RG-RAP73HD - 6
Bandingkan
RG-RAP73HD, Reyee Wi-Fi 7 Tri-Radio BE19000 Ceiling Access Point
Hotel, Office, etc.
Seri
  • Tri-radio performance, 6G/320MHz brings extre-high wireless rate
  • Better Streaming experience with Wi-Fi 7 exclusive feature MLO
  • Increase the high-density access capacity up to 1500
  • 4K-QAM, deliever data packs better for higher speeds
  • Capable of Enterprise Switch to build PRO Office Network
High-Performance Ceiling
Access Point
RG-RAP73HD
  • Wi-Fi 7 BE19000
    Hingga18658Mbps
  • MLO
    8K Ultra HD
  • 6GHz
    320Mhz
    Tri-Radio
  • Kapasitas Besar
    Hingga 1500 akses
  • Banyak Port
    1 2*Port 10GE , 1 SFP+
Surf The Future, See Never Seen
Learn more
Masuki Mesin Berkecepatan Tingkat-Lanjut,
Nikmati Akselerasi Sangat-Kencang yang
Sesungguhnya
Streaming Kualitas Sangat Tinggi,
Performa Meningkat 20%
Disponsori oleh MLO
Fitur Canggih Memberdayakan
Wi-Fi 7 ke Tingkat Lanjut
  • Reyee Mesh
  • Portal AP
  • Roaming Cerdas
Lebih Sedikit Kabel, Lebih Tenang Buat Autentikasi Aman dan Iklan Menjadi Jelas Definisi Ulang Roaming Optimal
Memanfaatkan Latensi yang
Sangat Rendah dan Kapasitas Tinggi
Switch PoE 10G Siap untuk Wi-Fi 7
Cloud, Memudahkan Bisnis Anda
  • Self-Organized Network
  • Pemantauan dan pemeliharaan jarak jauh
  • Upgrade firmware melalui Cloud
  • Update dinamik database APP
Spesifikasi Utama
  • Ceiling AP
  • Tri-radio
    12 spatial streams
    ● 2.4 GHz: 4 x 4, MU-MIMO
    ● 5 GHz: 4 x 4, MU-MIMO
    ● 6 GHz: 4 x 4, MU-MIMO
  • 18668 Mbps
  • 11528 Mbps
  • 5764 Mbps
  • 1376 Mbps
  • 2.4 GHz: 5 built-in omnidirectional antennas
    6 GHz: 5 built-in omnidirectional antennas
  • 258 mm x 258 mm x 59.5 mm (10.16 in. x 10.16 in. x 2.34 in.) (excluding the mounting bracket)
  • ≤ 2.0 kg (4.41 lbs.) (without packaging materials)
Number of 10GE SFP+ ports
    ● PoE+/PoE++
  • Yes, one DC power connector (48 V, 1.48 A)
  • 60 W
  • Ceiling/Wall
  • IP41
  • 512 (2.4 GHz)
    512 (5 GHz)
    512 (6 GHz)
    1024 (2.4 GHz, 5 GHz, and 6 GHz enabled)
Sumber daya All Resources
